Can't add a device
Fri Nov 11, 2022 9:41 pm
macguyincali offline
Can't add a device
Newbie here. I'm not sure exactly what happened but I tried to add an another device and for some reason it appears dimmed out already in the "configure" dialog so I can't select. I can't for the life of me figure out how to add it.
Fri Nov 11, 2022 10:46 pm
GlennNZ offline
Can't add a device
Hi
Screenshots probably would help.
If you are in the HomeKitLinkSiri (HKLS) Bridge config page and the device is greyed out - most likely you have already added it. Likely incorrectly; so you should select it - unclick the Publish Device - Make this device available on HomeKit checkbox and press save. Basically removing it from the bridge.
Then Save out of the config dialog for good measure. This will restart the Bridge and your Homekit apps should delete the device.
Then go back in and re-add as whatever is needed.
Glenn
