Filter by Manufacturer Name
Mon Aug 15, 2022 2:54 pm
Bildhauer offline
Hello
this script fails:
for dev in indigo.devices.iter("props.SupportsEnergyMeter") :
   if dev.enabled and dev.supportsStatusRequest and dev.zwManufactureName == "Greenwave":
      indigo.device.statusRequest(dev)
Main goal is to do an status update only to devices manufactured by "Greenwave".
Who can help? This are the device details:
batteryLevel : None
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
description :
deviceTypeId : zwRelayType
displayStateId : onOffState
displayStateImageSel : PowerOn
displayStateValRaw : True
displayStateValUi : on
enabled : True
energyAccumBaseTime : 2000-01-01 00:00:00
energyAccumTimeDelta : 0
energyAccumTotal : 0.0018
energyCurLevel : 0.2
errorState :
folderId : 85000692
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          SupportsEnergyMeter : true (bool)
          SupportsEnergyMeterCurPower : true (bool)
          SupportsEnergyMeterReset : true (bool)
          SupportsGasMeterReset : true (bool)
          SupportsPowerMeter : true (bool)
          SupportsWaterMeterReset : true (bool)
          address : 38 (integer)
          indigoObjVersion : 10 (integer)
          userEnergyPollingEnabled : false (bool)
          version : 4.21 (string)
          zwClassCmdBase : 37 (integer)
          zwDevEndPoint : 2 (integer)
          zwDevSubIndex : 1 (integer)
          zwManufactureId : 153 (integer)
          zwManufactureName : GreenWave (string)
          zwMeterSubTypeFlags : 5 (integer)
          zwMeterSupportsReset : true (bool)
          zwMeterType : 1 (integer)
          zwModelId : 196612 (integer)
          zwModelName : Relay Power Switch (string)
          zwShowDumpDevToLog : false (bool)
          zwShowEnergyPollingUI : true (bool)
          zwShowMainUI : false (bool)
          zwShowManualModifyConfigParmUI : false (bool)
          zwShowPollingUI : false (bool)
          zwShowSubmitModelInfoUI : false (bool)
          zwShowWakeIntervalUI : false (bool)
lastChanged : 2022-08-15 23:30:00
lastSuccessfulComm : 2022-08-15 23:30:00
ledStates : []
model : Relay Power Switch
name : Zwischenstecker Büro Bluetooth-Receiver (Steckdosenleiste 1 Dose 2)
onState : True
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
states : States : (dict)
     accumEnergyTimeDelta : 0 (integer)
     accumEnergyTimeDelta.ui : 0 seconds (string)
     accumEnergyTotal : 0.0018 (real)
     accumEnergyTotal.ui : 0.0018 kWh (string)
     curEnergyLevel : 0.2 (real)
     curEnergyLevel.ui : 0.2 W (string)
     onOffState : on (on/off bool)
subModel : ui=Relay Switch
subType :
supportsAllOff : False
supportsStatusRequest : True
version : 4.21
Best regards
Stephan O.
Mon Aug 15, 2022 6:55 pm
Re: Filter by Manufacturer Name
I think this will do it.
for dev in indigo.devices.iter("props.SupportsEnergyMeter"):
   if dev.enabled and dev.supportsStatusRequest and dev.ownerProps["zwManufactureName"] == "GreenWave":
Tue Aug 16, 2022 3:14 pm
Bildhauer offline
Thanks! I'll try!
Wed Aug 17, 2022 5:21 am
Bildhauer offline
Unfiortunately it doesn't to what I want it to do: at the end the devices should do an update in regards to the current power consumption. Any idea how to make it happen?
Best regards
Bildhauer
Wed Aug 17, 2022 5:39 am
When I tested the script, I only changed the manufacturer name and it worked:
   if dev.enabled and dev.supportsStatusRequest and dev.ownerProps["zwManufactureName"] == "Aeon Labs":
Can you describe what's not happening in greater detail?
Wed Aug 17, 2022 6:16 am
Bildhauer offline
Hello,
one an hour I am writing the power consumption into a file to monitor it. The "GreenWave" power strip does not update its energy parameters automatically. That's what I'm trying with this kind of script.
Best regards
Bildhauer
Wed Aug 17, 2022 6:20 am
Are you certain that it supports status update requests?
Wed Aug 17, 2022 6:46 am
Bildhauer offline
Pushing the "update" button its doing it …
Another idea is to update the Virtual Energy Meter devices linked to it. But there II'm facing issues like these:
   Virtual Energy Meter Error      Error in plugin execution ServerReplacedElem:
  File "plugin.py", line 328, in deviceUpdated
KeyError: key id 710455184 not found in database
Wed Aug 17, 2022 6:56 am
I have a Greenwave though haven’t used it for months.
Can’t you set polling to a specific time (ie hourly) rather than the default “when traffic detected”?
Wed Aug 17, 2022 11:33 am
Bildhauer offline
I’ll have a look at it!
