Change in Insteon behavior
Sun Jul 24, 2022 11:30 am
Hap offline
Running Indigo 2022.1
I have a scheduled trigger that runs at 3am to insure all the lights are off with the following actions:
turn off all lights (all INSTEON devices)
turn off "Great Room Corner"
turn off "Kitchen Cans Z"
The last two are Z-wave devices. However, it seems recently that all lights off turns off the FAN on the fan linc as well as light. Would prefer it not do that and I don't remember it doing so.
2022-07-23 03:00:00.508   Schedule   All Lights off Weekend
2022-07-23 03:00:00.578   Z-Wave   sent "Great Room Corner" off
2022-07-23 03:00:00.796   Sent INSTEON   "David's Garage Overhead Lights" off
2022-07-23 03:00:01.260   Sent INSTEON   "Workshop Lights" off
2022-07-23 03:00:01.343   Z-Wave   sent "Kitchen Cans Z" off
2022-07-23 03:00:01.344   Trigger   Kitchen Cans Off
2022-07-23 03:00:01.660   Sent INSTEON   "Becky's Garage Outside Light" off
2022-07-23 03:00:02.092   Sent INSTEON   "Master Bedroom Ceiling SwitchLinc" off
2022-07-23 03:00:09.086   Sent INSTEON   "Master Bedroom Ceiling Light" off
2022-07-23 03:00:09.518   Sent INSTEON   "Keypad - Master Bedroom Fan" off
Stripped out Matplotlib warnings as not relevant and snipped to the beginning/end of the problem area.
I could set it up to turn off each Insteon light individually, but that's going to be painful. I have a 184 devices listed in Indigo (yes, that's not the number of lights, but does elaborate the complexity of my setup).
Mon Jul 25, 2022 8:55 am
jalves offline
Re: Change in Insteon behavior
I have no idea what the right answer is, but as a work around could you add an action to the end of your 3 am trigger to toggle the fan back on?
Jeff
Mon Jul 25, 2022 8:56 am
That last device ("Keypad - Master Bedroom Fan") is the actual FanLinc or the KeypadLinc that's controlling the FanLinc?
Fri Jul 29, 2022 5:58 pm
Hap offline
I've been looking at this harder, it's the KeyLinc that you see in the logs.
However, the fan is off every morning when my wife gets up ~0530 and there is nothing in the logs to indicate it was turned off, triggered off, or scheduled off other than the Keylinc.
Weekdays, the evening off is at 1130 pm, weekends it is at 0300 am.
I tried to set up a 15 minute repeating schedule to request Fan status, but couldn't see an easy way to do that.
Fri Jul 29, 2022 8:40 pm
ryanbuckner offline
I have this same issue. I wound up not using the "turn off all" function and instead using 2 action groups. 1 action that turns off all lights, and 1 that turns off fans.
Sun Jul 31, 2022 3:35 pm
Hap offline
I created an Action group to turn off my Insteon lights. We'll see if that works.
I figured out the Keypad Fan log item above is a triggered item to keep the keypad in sync with the fan. So something told the fan to turn off (not logged) and that triggered the Keylinc Sync.
