Inconsistent use of space and tabs?
Wed Jul 13, 2022 3:30 am
Bildhauer offline
Hello,
I'm getting the error message m. a. compiling this script:
import datetime as dt
from datetime import date
today = dt.datetime.now()
yesterday = today - dt.timedelta(days=1)
now = dt.datetime.now()
BeginnLetzteStunde = now.hour-1
emailBody=""
if BeginnLetzteStunde == -1 :
   BeginnLetzteStunde =23
if BeginnLetzteStunde == 1 :
   emailBody = u"Datum\tUhrzeit\tVerbrauch [Wh]\n"
for dev in indigo.devices.iter("props.SupportsEnergyMeter") :
     if dev.enabled and dev.name == "Verbrauch Grenzweg stündlich" :
emailBody=""
      emailBody = emailBody + u"{}\t{}\t{}\n".format(today.strftime("%d.%m.%Y"), today.strftime("%H:%M"), round(dev.energyAccumTotal,2))
Str_heute=str(yesterday.strftime("%Y%m%d"))
import os.path
save_path = '/Users/smerckens/Desktop/Z-Wave Exporte/'
filename = Str_heute+'.Export des stündlichen Verbrauchs'
completeName = save_path+filename
file1 = open(completeName , "a", encoding='utf-8')
file1.write(emailBody)
file1.close()
import os.path
file1.close()
What do I need to of to get of it in line 14 ("emailBody = emailBody + u"{}\t{}\t{}\n".format(today.strftime("%d.%m.%Y"), today.strftime("%H:%M"), round(dev.energyAccumTotal,2))"?
Thanks in advance for your help!
Best regards
Bildhauer
Wed Jul 13, 2022 4:58 am
Re: Inconsistent use of space and tabs?
The error you posted is telling you what the problem is -- an inconsistent use of spaces and tabs. In looking at the script you posted, I can see that some lines are indented with three spaces, some with five and some with six (well, 1 -- but I'll get to that in a sec). Also, you suggest the problem is with line 14, but the line you posted below the code is line 27 which is a bit confusing. You should make each indention the same 4 spaces. A second indention should be 8 spaces, and so on. Some of your indentions are 5 spaces followed by a 1 space indention.
Second, you don't need to import a library more than once in your script (and for a short script like this, there is no reason to do conditional imports). The convention is to import them at the top. I've removed the extras.
Third, it looks like you've repeated the same block of code twice at the end (that might be a copy/paste issue).
I did this quickly but I think it's right (so there might be an error).
import os.path
emailBody=""
# for dev in indigo.devices.iter("props.SupportsEnergyMeter") :
#     if dev.enabled and dev.name == "Verbrauch Grenzweg stündlich" :
#         import datetime as dt
# from datetime import date
emailBody=""
# import os.path
file1.close()
# Str_heute=str(yesterday.strftime("%Y%m%d"))
# import os.path
# save_path = '/Users/smerckens/Desktop/Z-Wave Exporte/'
# filename = Str_heute+'.Export des stündlichen Verbrauchs'
# completeName = save_path+filename
# file1 = open(completeName , "a", encoding='utf-8')
# file1.write(emailBody)
# file1.close()
Wed Jul 13, 2022 5:07 am
There's repetition in the first block of code, too. I think this should be close:
import os.path
BeginnLetzteStunde = today.hour-1
emailBody=""
file1.close()
Wed Jul 13, 2022 6:58 am
Bildhauer offline
Thx. I will check …
Thu Jul 14, 2022 11:15 am
Bildhauer offline
Thx, it's doing its job!
Bildhauer
Thu Jul 14, 2022 11:45 am
Good deal. Glad to hear that's working for you. A couple more notes to think about that are absolutely not necessary for the script to run, but I would recommend anyway:
1. The current convention for working with file objects is to use "with open". The "with" operation will close the file for you. I've updated the attached to reflect that.
2. If you're using Python 3, there is no longer a need to identify Unicode strings like u"string"; in Python 3, all strings are Unicode strings. I didn't change those.
3. You can add strings together using "+=" rather than emailBody = emailBody + "string"
import os.path
emailBody = ""
if BeginnLetzteStunde == -1:
    BeginnLetzteStunde = 23
if BeginnLetzteStunde == 1:
for dev in indigo.devices.iter("props.SupportsEnergyMeter"):
    if dev.enabled and dev.name == "Verbrauch Grenzweg stündlich":
        emailBody += u"{}\t{}\t{}\n".format(today.strftime("%d.%m.%Y"), today.strftime("%H:%M"), round(dev.energyAccumTotal,2))
Str_heute = str(yesterday.strftime("%Y%m%d"))
filename = Str_heute + '.Export des stündlichen Verbrauchs'
completeName = save_path + filename
with open(completeName , "a", encoding='utf-8'):
Thu Jul 14, 2022 3:00 pm
While you're at it, you can delete these lines as they're not doing anything:
import os.path
Sun Jul 17, 2022 10:39 am
Dual offline
I enjoy reading the responses from you two. It’s like a mini tutorial. Thanks!
Wed Aug 03, 2022 1:09 pm
Dave, for completeness you’ve a typo in your post above.
“wtih” not “with”.
Wed Aug 03, 2022 3:39 pm
Pedantry! I love it. Fixed.
Thanks for the heads up.
