Errors about hubNumber
Mon Jul 04, 2022 3:55 pm
nathanw offline
I'm getting a steady stream of this in the log after updating to 2022.11.31
   Hue Lights Error
  File "plugin.py", line 5776, in parseAllHueLightsData
    hubNumber = device.pluginProps['hubNumber']
KeyError: 'key hubNumber not found in dict'
   Hue Lights Error
  File "plugin.py", line 6361, in parseAllHueGroupsData
And there's this at startup:
   Hue Lights                      bridge lights groups scenes users resources rules schedules sensors hostIds / user names ------------------- ip Numbers ---- BridgeIds-------
   Hue Lights                      #0          9      5     25   106         2    26         2       4 928ad94194c7dc6980e43507b02cdb89 192.168.86.66   001788FFFE255190
   Hue Lights Warning              Device Hue - C bedroom has no active hue bridge associated, used bridge# is:-1
   Hue Lights Warning              Device Hue - Living room floor lamp side has no active hue bridge associated, used bridge# is:-1
   Hue Lights Warning              Device Hue - Living room floor lamp top has no active hue bridge associated, used bridge# is:-1
   Hue Lights Warning              Device Hue - Nathan's floor lamp has no active hue bridge associated, used bridge# is:-1
   Hue Lights Warning              Device Hue - Nathan's floor lamp bottom has no active hue bridge associated, used bridge# is:-1
   Hue Lights Warning              Device Hue - Nathan's floor lamp middle has no active hue bridge associated, used bridge# is:-1
   Hue Lights Warning              Device Hue - Nathan's floor lamp top has no active hue bridge associated, used bridge# is:-1
   Hue Lights Warning              Device Nathan's office light has no active hue bridge associated, used bridge# is:-1
   Hue Lights Warning              Device Upstairs hallway has no active hue bridge associated, used bridge# is:-1
Tue Jul 05, 2022 10:34 am
Re: Errors about hubNumber
how many bridges do you have? just one?
Anyway: please go to menu/config and re-pair the bridge
and please do a menu/print hue config data /
print lights
and
print all info for one light , select any of the light devices
could you post or send to my email karlwachs at me com
and try to edit one of the light and re select the bridge number
ps and your host id seems to be short:
928ad94194c7dc6980e43507b02cdb89  yours
VeJ2NdE0m-zmQJ0EGoWw2IUHmw3RPDLgty159l03  mine
what bridge version type are you using?
Tue Jul 12, 2022 7:03 pm
nathanw offline
Apologies for posting this and then not being able to keep debugging. I was frustrated enough with the whole arrangement that I got rid of all the Indigo Hue devices, uninstalled the plugin, and then started over from scratch, and it works now.
Users browsing this forum: t-star and 4 guests
