DSC Alarm Plugin error message
Thu Jun 09, 2022 4:08 am
RDLSAT offline
System Info:
MacOS High Sierra: 10.13.6 (17G14042)
Indigo Version: 2022.1.1
Plugin ID: com.frightideas.indigoplugin.dscAlarm
Plugin Release: v2022.0.2 released on May 29, 2022
Alarm Panel: DSC 1616
Interface: Envisalink EVL-4EZR
I am receiving the following error from the Indigo software when initializing the DSC Alarm Plugin...
DSC Alarm Error Envisalink refused login request.
What can I do to fix this?
See Event Log below
Starting plugin "DSC Alarm 2022.0.2" (pid 19330)
Started plugin "DSC Alarm 2022.0.2"
DSC Alarm
==================== Initializing New Plugin Session ======================================================
Plugin name: DSC Alarm
Plugin version: 2022.0.2
Plugin Log Level: Info
Indigo version: 2022.1.1
Python version: 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
Mac OS Version: 10.13.6
Process ID: 19330
DSC Alarm Initializing communication at address: 192.168.1.18:4025
DSC Alarm Communication established
DSC Alarm Warning Plugin will attempt to re-initialize again in 3 minutes.
Thu Jun 09, 2022 5:30 am
Re: DSC Alarm Plugin error message
Has it been working or are you a new user to the plugin?
Thu Jun 09, 2022 6:42 am
durosity offline
Sounds like the envisalink is already in use by something else.. is it connected to an app or something?
Thu Jun 09, 2022 7:00 am
viewtopic.php?t=21603&p=169482
Are you using password “user”?
https://forums.homeseer.com/forum/secur ... ost1102626
Thu Jun 09, 2022 9:25 am
RDLSAT offline
New to using the DSC plugin. Evisilink 4 was just recently connected to the alarm panel.
I am using the Eyezon iOS App and the web browser interface. They are both working.
Password is 12 digit alphanumeric with special characters.
Thu Jun 09, 2022 9:31 am
RDLSAT offline
I reset the password to "user" and it works. Thanks!
Is there a way to reset the default password?
See Event Log below
Starting plugin "DSC Alarm 2022.0.2" (pid 41465)
DSC Alarm
Process ID: 41465
DSC Alarm Connected to Envisalink.
Thu Jun 09, 2022 10:20 am
Monstergerm offline
The EyezOn account login is different from the envisalink device login. For Envisalink-4 the password can be 10 characters max. This is the password you enter in the DSC plugin config dialog.
To change the Envisalink password, log into the device through its built-in web server using its IP address (preferably a fixed IP address) and change the password there.
Here is the info from the Envisalink TPI:
Enivsalink 3 vs Envisalink 4 Difference
The Envisalink 3 only supports 6 ASCII digits for a password but the Envisalink 4 supports 10.
IMPORTANT: Envisalink Application Firewall
As of Envisalink 4 (1.0.102) and Envisalink 3 (1.12.180) the Envisalink has an internal firewall that will block all TPI connections that originate outside of the network segment it resides upon. This is to protect users who expose their Envisalinks to the public Internet either by mistake or ignorance. This feature can be disabled by changing the default user's password from “user” to any other password, 4 characters or longer.
Wed Jun 29, 2022 7:27 am
pgershon offline
I recently changed the IP address on my Envisalink 3 and started to receive error messages. Any idea what might be going on? I am still using the user password/account. Any idea what might be going on. Worked fine until yesterday.
Jun 29, 2022 at 9:14:10 AM
   Reloading plugin "DSC Alarm 2022.0.2" using API v3.0
   Stopping plugin "DSC Alarm 2022.0.2" (pid 716)
   Stopped plugin "DSC Alarm 2022.0.2"
   Starting plugin "DSC Alarm 2022.0.2" (pid 1325)
   DSC Alarm
                                   Mac OS Version:      12.4
                                   Process ID:          1325
   DSC Alarm                       Initializing communication at address: 192.168.1.11:4025
   DSC Alarm Error                 Timed out after waiting for response to command 001 for 3 seconds, retrying.
   DSC Alarm Error                 Checksum did not match on a received packet.
Jun 29, 2022 at 9:24:19 AM
   DSC Alarm Error                 Resent command 000 3 times with no success, aborting.
Wed Jun 29, 2022 9:40 am
pgershon offline
Updating - rebooting the Envisalink from its web page fixed everything
