Shims issue after upgrade
Mon Jun 06, 2022 11:36 am
roquej offline
Have this configuration, that was working great before the upgrade bonanza.
Screen Shot 2022-06-06 at 12.33.17 PM.png (131.04 KiB) Viewed 2650 times
Now, not getting anything in the logs, even with Shims set to "verbose debug". MQTT Connector seem to be working:
MQTT Connector Debug MQTT Broker: processReceivedMessage: homeassistant/climate/house_nativezone/temperature, payload: 76
But the trigger never gets nor shows in the log.
Ideas?
Screen Shot 2022-06-06 at 12.40.14 PM.png (96.01 KiB) Viewed 2650 times
Mon Jun 06, 2022 11:57 am
FlyingDiver online
Re: Shims issue after upgrade
Unfortunately, not really. Have you tried just recreating that trigger?
Mon Jun 06, 2022 2:29 pm
roquej offline
I deleted the trigger and recreated it. Rebooted.
MQTT message is correct:
MQTT Connector Debug MQTT Broker: processReceivedMessage: homeassistant/sensor/house_nativezone_temperature/state, payload: 75
Logging is set to debug. The trigger never hits.
Again, this was working well before the upgrades.
As a nice, I am using ShellyMQTT and everything works there.
There is something going on with the MQTT Connector or the MQTT Shims plugins.
JP
Mon Jun 06, 2022 2:33 pm
FlyingDiver online
If the trigger never fires, it's not getting to the Shim. So it would have to be a connector issue.
That's a different topic than the ones from the screen shots. Previously you had "climate", now "sensor". Is this two different topics, with two different triggers? Both failing?
Any chance you can replicate this with a new database with just the trigger in it? Probably don't even need a shim.
Mon Jun 06, 2022 2:36 pm
roquej offline
1. downgraded both MQTT Connector and MQTT Shims. Triggers started working again.
2. upgraded MQTT Shims, triggers continued to work
2. upgrade MQTT Connector, triggers stopped working
There is something going on with the MQTT Connector plugin.
JP
Mon Jun 06, 2022 2:40 pm
FlyingDiver online
JP
Understood, but on my system they work as expected. So unless I can get something that exhibits the problem I'm stuck. Maybe take your existing database, make a copy, and delete all the non-MQTT stuff?
Mon Jun 06, 2022 2:42 pm
FlyingDiver online
Oh, and what's the latest version that does work? Python2 or Python3?
Mon Jun 06, 2022 2:59 pm
roquej offline
Python 2 v0.4.10
Mon Jun 06, 2022 3:28 pm
FlyingDiver online
Doesn't ShellyMQTT use the standard MQTT-Connector trigger system? And those triggers show in the log?
Mon Jun 06, 2022 3:58 pm
FlyingDiver online
Your issue sounds a lot like this one: viewtopic.php?f=316&t=26222
That was fixed by deleting and recreating all the mqtt devices and triggers. So I never did find out what was wrong with what he had.
I compared the trigger detection code between 0.4.10 and current, and it's essentially unchanged. Mostly formatting changes to clean it up for Python3.
The only thing I have left to try is running your database on my dev system so I can run the plugin through the debugger. I have a few hours to look at that tomorrow, otherwise it'll be the weekend.
Tue Jun 07, 2022 11:01 am
roquej offline
Finally was able to get the db clean up to send to you. How can I send?
JP
Tue Jun 07, 2022 11:03 am
FlyingDiver online
Sent PM.
Tue Jun 07, 2022 11:50 am
FlyingDiver online
Ok, there's definitely something weird going on. I think it has to do with the processing of the "End" statement in the match list. That's only needed when you have topics of variable length and need to match on both the short topic and the longer topic (which contains the short topic). Such as "foo/bar" and "foo/bar/alpha" both having their own triggers.
In your case, I don't think you need it. So take it out and see if your triggers work. Meanwhile I'll see if I can figure out why it's failing, as I know it used to work.
Tue Jun 07, 2022 2:43 pm
FlyingDiver online
Try this pre-release with your existing triggers with the 'End' term: https://github.com/FlyingDiver/Indigo-M ... g/2022.0.3
There's got to be some subtle difference in the way exceptions are handled between the Python versions, as the plugin was using an exception to catch an end of array error to determine if the End term was correct. That worked in Py2, but failed in Py3. So I'm testing for the correct number of topic components differently now, which works in Python3.
Tue Jun 07, 2022 2:52 pm
roquej offline
That worked.
Cool - thank you!
JP
