Error retrieving Hue device status: resource, /lights/18...
Thu Jun 02, 2022 5:29 pm
   Hue Lights Error                Error retrieving Hue device status: resource, /lights/18, not available
this format of error is not something I've seen before. The plugin (1.10.21) seems to be working properly. Reloading the plugin doesn't fix it. If this is a problem with a specific device, and there's a way to give its Indigo or Hue name instead of "18" that would be much preferred for troubleshooting.
Fri Jun 03, 2022 2:49 pm
Re: Error retrieving Hue device status: resource, /lights/18
I added the device name to the error message.
You can list all the lights in menu/print hue info/lights. there you can find the light# and the indigo device number
like this:
======================= print Hue Lights =====================
==  Bridge:0, ipNumber:192.168.1.232, hostId:920-z7SbNI4X9xagRZuSaJmoqp3DiJEtIm0yYunl, paired:True, #of lights:28, sorted by:id
 ID ONoff Reach modelId--------- type--------------------- uniqueid------------------ Name------------------------------- ProductId-------------------- manufacturername------------- ProductName------------------ Group indigoDevName-----
 10   1     0   5063130P7        Extended color light      00:17:88:01:09:d8:87:38-0b Küche spot 1                        Philips-LCG002-3-GU10ECLv2    Signify Netherlands B.V.      Hue Fugato color spot         4     Hue_light_0_10_Küche spot 1
 11   1     0   5063130P7        Extended color light      00:17:88:01:09:e0:99:98-0b Küche spot 2                        Philips-LCG002-3-GU10ECLv2    Signify Netherlands B.V.      Hue Fugato color spot         4     Hue_light_0_11_Küche spot 2
The error comes from:
it tries to retrieve info for light # 18 but the bridge does not return info
you can switch on debug (4) read and (5)send in config
hope that helps
