Python 3 & Indigo 2022.1
Thu May 19, 2022 12:50 pm
SMUSEBY offline
I have a script that is failing with the message
Script Error control page "0 Common" script error in file gDoorRFID OPEN.py:
Script Error inconsistent use of tabs and spaces in indentation
Script Error around line 18 - "time.sleep(1)"
The entire script:
#   opens fDoor if fDoor interlock variable is true; interlock true for 1 sec
import time
fDoorInterlock = indigo.variables[911502153].getValue(bool)
hseStatus = indigo.variables[1176596514].getValue(bool)
if hseStatus:
   indigo.variable.updateValue(911502153, value = "True") #set to true enabling operation of door latch
if fDoorInterlock:
   exec(open("/Library/Application Support/Perceptive Automation/Scripts/RFID-Access-Control.py").read())
    time.sleep(1)
    indigo.variable.updateValue(911502153, value = "False") #set to false
Quoting the code above shows lines 18 and 19 with a one character indent; the code in BBEdit does not show that extra space.
I have no idea how to fix this error.
Suggestions?
Thu May 19, 2022 2:01 pm
Re: Python 3 & Indigo 2022.1
Use the "Convert tabs to spaces" command in BBEdit. And set your prefs to use spaces and not tabs.
Fri May 20, 2022 3:14 pm
SMUSEBY offline
That seems to have fixed the issue - by deleting the tabs, and adding spaces. I was unable to find the preference 'use spaces not tabs'. The closest I could find was in the 'editor defaults menu', and selecting '1 space per tab'. I don't think that's correct because I got the same error until I manually deleted the tabs and inserted spaces.
Can you point me to the location for the default to spaces for tabs?
Bob
Fri May 20, 2022 3:19 pm
I think it's actually the "auto expand tabs" option.
Screen Shot 2022-05-20 at 5.18.16 PM.png (302.54 KiB) Viewed 647 times
