Trane Nexia plugin updated for Indigo 2022.1
Wed May 11, 2022 7:16 am
Sun May 15, 2022 5:54 pm
roquej offline
Re: Trane Nexia plugin updated for Indigo 2022.1
Thank you for the plugin!
One questions and one error:
Error:
When trying to "Select Zone Present ", getting:
Error (client) dialogForActionId() caught exception: PAXDialogControllerError -- Fields must contain a valid 'type' attribute: textfield, menu, checkbox, list, separator, label, button.
Question:
For the Thermostat devices, one of the options is "thermostat". However, not choice are present. Is this normal?
JP
Sun May 15, 2022 10:21 pm
I don’t recognize the text “select zone present” off the top of my head. Where are you seeing that? Might need a screen shot.
Ditto on the second item. What exactly are you doing to get to that point. Don’t forget, Trane has this unusual differentiation between thermostats and zones. You’ll have a thermostat for each HVAC unit and then some number (maybe only one) of zones associated with the thermostat. The zones are the actual Indigo thermostat devices, as that’s where the temp setpoints are.
Mon May 16, 2022 6:39 pm
roquej offline
What action triggered the error:
Cause of error
Error cause.jpg (281.18 KiB) Viewed 1775 times
Action behind the question:
Question location
Question location.jpg (247.77 KiB) Viewed 1775 times
Mon May 16, 2022 9:23 pm
Fri May 20, 2022 3:22 pm
Fixed in 2022.0.2.
Thu Jun 02, 2022 6:25 pm
roquej offline
Posted the defect in github, but just to circle back here, turning the system off doesn't work. Either via the device or action.
Thank you for all you!
JP
Thu Jun 02, 2022 6:28 pm
That one's getting a complete rewrite to upgrade to the latest Python 3 library. It's going to be a while.
Sun Jan 15, 2023 9:56 am
welchgregusa offline
Thanks for the rewrite effort. (I live in FL too — heat coming on more these days!) I'm poking around to see if I can discover anything related to updates not happening.
Sat Jul 29, 2023 10:03 am
roquej offline
I opened another issue in GitHub.
The plugin seems to work well when you use the Thermostat device to control the AC. However, many of the Actions seem to have issues. I will keep testing and opening GitHub issues.
As always, thank you for all you do. Grateful for your work!.
JP
Sat Jul 29, 2023 11:04 am
Don't bother opening any issues against the current store version. I'm in the middle of converting the plugin to the latest nexia library, which is a major rewrite since it's asyncio based.
I'll have a pre-release of that version soon.
