SearchCz wrote:Does this plugin work with the Nanoleaf Essentials A19 bulb ?
autolog wrote:SearchCz wrote:Does this plugin work with the Nanoleaf Essentials A19 bulb ?
I don't know as I haven't tested it. I have tested with the Aurora (triangle) and Canvas (square).
More recently, I have been having issues with my Auroras but the Canvases are OK.
It would probably need some code changes to support the A19.
Different Computers wrote:Even if the API investigation goes nowhere, since these are HomeKit bulbs, you could use HomeKit Bridge and the virtual switch trick to control them.
1. create a virtual switch. Let's call it A19 Control.
2. Publish it to HomeKit via HKB.
3. Create a HomeKit automation that turns on the A19 any time A19 Control turns on, etc.
4. Automate the A19 Control as you normally would in Indigo.
autolog wrote:OK, I can take a hint.
I have just ordered one for testing.
Once I get it, I will schedule in some time to include support for it in the plugin.
