Karl,
Thanks again for all your work and the update.
I can confirm the Fingscan plugin 7.32.67 works perfect with:
Mac OS 10.14.6 and Indigo 7.4.1
But with:
Mac OS 10.14.6 and Indigo 2021 2.0
The only strange thing into the log every ~ 2 minutes:
(But it seems to be it’s working well and I have saved the config again a couple of times)
Did a downgrade to 7.32.65 and errors are gone.
fingscan Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 4659, in runConcurrentThread
File "plugin.py", line 4836, in dorunConcurrentThread
File "plugin.py", line 854, in sendWakewOnLanAndPing
File "plugin.py", line 887, in sendWakewOnLan
error: [Errno 65] No route to host
fingscan Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
fingscan myLogSet setting parameters -- debug settings :[]
fingscan FINGSCAN-- initializing will take ~ 2 minutes..
fingscan Warning leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
fingscan getting password
fingscan get password done; checking if FING is installed
fingscan fing install check done
fingscan loaded indigo data
fingscan Warning network info: {'netWorkId': '192.168.178.1', 'broadcast': '192.168.178.254', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.178.1 - 192.168.178.254'}, netwType:24
fingscan ifind plugin: com.corporatechameleon.iFindplugBeta
fingscan MAP2Vendor initializing
fingscan MAP2Vendor downloading raw files, will take some minutes
fingscan /usr/bin/curl -L
https://standards.ieee.org/develop/regauth/oui/oui.csv | tail -n +2 | cut -d',' -f'2,3' | sed 's/"//'> '/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/com.karlwachs.fingscan/mac2Vendor/oui' &
https://standards.ieee.org/develop/rega ... 28/mam.csv | tail -n +2 | cut -d',' -f'2,3' | sed 's/"//'> '/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/com.karlwachs.fingscan/mac2Vendor/mam' &
https://standards.ieee.org/develop/rega ... /oui36.csv | tail -n +2 | cut -d',' -f'2,3' | sed 's/"//'> '/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/com.karlwachs.fingscan/mac2Vendor/oui36' &
fingscan MAP2Vendor initializing still waitinmg for download
fingscan Initializing parameters for FING
fingscan Waiting for first data from FING
13 Apr 2022 at 11:09:36
fingscan Checking if FING created output, old timeStamp:1649840922.69; new timeStamp:1649840958.43
fingscan Initializing .. FING created new data waiting ~ 1 minute for stable operation
fingscan FING Pids active after step3 = [u'97123']
fingscan (re)started FING, initialized
fingscan Error --> setup config, save, then a manual reload of plugin
fingscan --> while loop break stopping ... quitNOW was: please setup config , waiting
fingscan Error --> you have 2 minutes to fix config, before restart
