Startup failure after latest Catalina update and 2021.2 upd
leebu
Post by leebu »
Today I did the latest Catalina update and after the restart was notified of the 2021.2 update so I did that too...
Now HomeKit Bridge does not start and I am not getting errors in the log (advanced debug is on) to indicate why. I also don't know which update may be causing the problem...
Here is the error in the system log:
Mar 19, 2022 at 12:26:08 PM
HomeKit Bridge Error HomeKit server 'HomeBridge' could not be started, please check the service logs for more information,
now issuing a forced shutdown of the service to be safe.
If you continue to have problems starting this server use the Advanced Plugin Actions menu option to rebuild the Homebridge folder.
Instructions at https://github.com/Colorado4Wheeler/Hom ... dge-folder
HomeKit Bridge Attempting to stop 'HomeBridge'
HomeKit Bridge HomeKit server 'HomeBridge' has been stopped
The plugin.log is attached but I'm not seeing any actionable errors...
Lee
plugin.log
(282.74 KiB) Downloaded 110 times
cuhouse
Re: Startup failure after latest Catalina update and 2021.2
Post by cuhouse »
Lee,
I have had to update the following in the referenced link each time I update to a new version of Indigo. I just did it for 2021.2 to get HomeKit Bridge to work.
viewtopic.php?f=201&t=22522#p177981
Maybe it will help you?
Jody
Return to “HomeKit Bridge”
