Hue Lights discussion
Re: Hue Lights discussion
https://github.com/nsheldon/Hue-Lights- ... ag/v1.8.66
fixed some more errors ie
Hue Lights Line 197 has error=list index out of range
this should be the first non beta for
- no entry in supported devices needed for new lamps
- has print function for hue info from hue hub
- supports multiple hue bridges
https://github.com/nsheldon/Hue-Lights- ... ag/v1.8.70
Version 1.8.0 Posted
- Added support for all light types without the need to update the plugin for every new model of light.
- Added support for multiple Hue Bridges.
- Added Plugins menu option to print device details to the log
Maybe a bug introduced with the new version?
I set the brightness using the field, I do not want the brightness taken from a variable/other device.
- Schermata 2022-02-07 alle 14.44.28.png (133.27 KiB) Viewed 3200 times
I also got this error:
Hue Lights Error Error in plugin execution ExecuteAction:
File "plugin.py", line 11496, in recallScene
File "plugin.py", line 5519, in getIdsFromDevice
AttributeError: 'NoneType' object has no attribute 'pluginProps'
I have the second fixed in v 1.8.1
Want test a little longer. Will post tomorrow.
is there anything in the log for the first post?
Karl.
Karl.
please try:
https://github.com/nsheldon/Hue-Lights- ... tag/v1.8.1
should take care of both issues
Thank you for all of the updates. I'm using 1.8.2 and am getting this error a lot:
File "plugin.py", line 10874, in setColorTemperature
AttributeError: 'unicode' object has no attribute 'formate'
fixed in dev branch
https://github.com/nsheldon/Hue-Lights- ... tag/v1.8.3
was a typo when I replaced all unicode() functions, to be ready for python 3.9
Nathan should put this into the regular download, but if you want to use it now download from the posted link
Thank you!
Seem to be having another little issue. I have 2 Hue Gateways. When I go to add a new device and choose light "x" from Gateway1, it says error: light "x" is already being controlled by an Indigo Device , but this is not true. Even if I delete light "x" from the Philips Hue app and re-add it fresh, I get the same error. When I go to the Indigo Device which the plugin thinks is controlling my new light, the plugin window continues to tell fibs by showing light "x" as selected, but the Indigo Device is actually controlling light "y", and light "y" is working perfectly normally. I'm baffled!
- Screen Shot 2022-02-15 at 8.09.12 PM.png (93.3 KiB) Viewed 3073 times
Thanks for the report. Could you share debug logs showing this? In Indigo, go to Plugins -> Hue Lights -> Toggle Debugging then reload the plugin (Plugins -> Hue Lights -> Reload). Reproduce the error and share the logs in your reply (or a private message if the logs are too long to share in a post).
I know what it is:
it compares the hub bulb- ids and this can be the same for 2 indigo devices. hubs start their ids with #1 ...99 so you can have bulbID =5 on both hubs.
we/i need to add the check if hub# is the same
we need to add
to
in several places
we need to add
and valuesDict['hubNumber'] == otherDevice.pluginProps.get('hubNumber', 0)Code: Select all
if valuesDict['bulbId'] == otherDevice.pluginProps.get('bulbId', 0):Re: Hue Lights discussion
please check:
https://github.com/nsheldon/Hue-Lights- ... tag/v1.8.4
that should fix it.. and nathan could you move this to production?
Nathan,
had to do this fix in 10 places for bulbId , groupId, and sensorId
Nathan,
if valuesDict['bulbId'] == otherDevice.pluginProps.get('bulbId', 0) and hubNumber == otherDevice.pluginProps.get('hubNumber', 0)Code: Select all
if sensorId == otherDevice.pluginProps.get('sensorId', 0) and hubNumber == otherDevice.pluginProps.get('hubNumber', 0) Code: Select all
if valuesDict['groupId'] == otherDevice.pluginProps.get('groupId', 0) and hubNumber == otherDevice.pluginProps.get('hubNumber', 0):Re: Hue Lights discussion
You guys are amazing. Thank you for all the time & effort you put into these plugins. Problem solved!
