- Code: Select all
IT-100/Envisalink Error (011): Keybus Transmit Time Timeout
durosity wrote:No, no keypadproblen=ms and, other than the error messages from the plugin, the alarm seems to function properly. At least it follows zone changes.Are you having any issues with your keypads at all? If not could just be a wiring fault with the envisalink. If memory serves there's a way to monitor the keypads and show it in alarm memory if it faults, so if it doesn't come up on a keypad I'd suspect the envisalink/wiring.
durosity wrote:Yup. Pulled the battery, pulled the fuse, had a cupa coffee....Tried restarting the system?
Monstergerm wrote:That was it. Yes, the alarm time had drifted and I had just ignored it since we only use the system for home automation purposes. Time reset, error messages disappeared. Thanks!I am wondering if this has anything to do with transmitting the Time. Is your Envisalink monitored by EyezOn? Sometimes they get slightly different error messages. So to doublecheck, is the time of the panel correct and in sync with the Indigo Server time? Is everything else working fine with the Envisalink?....
Monstergerm wrote:I am glad you got it to work. Out of curiosity, how much was the time difference between the panel and the Indigo Server?
