After chatting with Nathan, I am going forward to add the following feature:
The plugin will only use device types for the light devices (not yet sensors = switches) not the modelId anymore
This will enable to model id not any more required to add new lamp types, the plugin will auto detect the right type of lamp and know which functions it can use.here are the types I have found:
Dimmable light
Extended color light
Color light
Color temperature light
Dimmable light
On/Off plug-in unit
I need some one to check if these are all device types,...
==Enable hue plugin debug in config, restart plugin
in indigo log
find u'type':
in section
loaded lights list - {u'11': {u'swversion': u'1.65.11_hB798F2', u'name': u'Library spot 3', u'swupdate': {u'state': u'transferring', u'lastinstall': u'2022-01-21T21:14:26'}, u'productid': u'Philips-LCG002-3-GU10ECLv2', u'uniqueid': u'00:17:88:01:0c:39:74:32-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Fugato color spot', u'state': {u'on': True, u'hue': 36069, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.2272, 0.3807], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 153, u'sat': 178}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'B6B8B914', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'doublespot'},
>>>>>> u'type': u'Extended color light', <<<<<< like this one
u'modelid': u'5063230P7'}, u'10': {u'swversion': u'1.65.11_hB798F2', u'name': u'Library spot 4', u'swupdate': {u'state': u'transferring', u'lastinstall': u'2022-01-21T21:14:16'}, u'productid': u'Philips-LCG002-3-GU10ECLv2', u'uniqueid': u'00:17:88:01:0c:39:76:1f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0. ....
I need to know If I there are other dev types other than in the list above
if you could post the results
