Fibaro Smart Implant
Sat Mar 28, 2020 2:01 pm
McJohn offline
Re: Fibaro Smart Implant
matt (support) wrote:
Have you tried a complete reset of it? That is: exclude, re-include, re-sync, and re-configure settings in Indigo's UI?
Just done all the things you said but unfortunately no results.
Sun Mar 29, 2020 3:45 am
Nick offline
My status of adding 24v rain sensor. Did not get any result of the switching of the rain sensor on Binary IN1. Played with it for a few hours or so. Then used a binary door magnet sensor to see if that would work. Didn't on Bin 1. But after connecting it on Binary IN 2 it worked on that input. Don't ask me why. Tried it on Binary IN 1 and it also worked. Than connected the rain sensor and it worked. Both Bin 1 and Bin 2 are giving updates.
It almost seems that both inputs of the smart implant needs to activated ore something. Keep seeing some real weird behavior on this type of module.
And the other module with 2 analog input still going strong.
Sun Mar 29, 2020 3:50 am
McJohn offline
Thanks for the update.
What kind of firmware do your Implants have?
Ours have 5.01 but I saw their is also version 5.1.
Wed Apr 01, 2020 1:18 pm
Nick offline
According to the numbering of indigo it is 5.01. My understanding this is the 5.1 version. I have a fibaro home center light to do updates on the fibaro modules but two months ago their was no newer firmware than 5.01/5.1. Will do a check this weekend to see if their is a new update.
Fri Nov 26, 2021 3:11 am
racarter offline
Is there any way to stop temperature updates from this device being published in the event log?
Fri Nov 26, 2021 3:39 pm
The device settings for the temperature sensor device (device edit dialog, select temperature tab panel and edit settings) should have a Hide temperature message broadcasts in Event Log checkbox.
Fri Nov 26, 2021 3:49 pm
racarter offline
It doesn’t Matt - that was the first place I looked.
Sat Nov 27, 2021 10:24 am
Re-sync it and copy/paste the Event Log results into a reply for me. Also, is the model ID on it FGBS-222?
Sat Nov 27, 2021 11:12 am
racarter offline
Hi Matt
Yes, FGBS-222
Here's the log:
Z-Wave Syncing - started for "Doorbell In"
Z-Wave Syncing - retrieved module neighbors list: 3, 4, 6, 7, 11, 12, 13, 15, 17, 18, 19, 20, 22, 26, 27, 28, 29, 30, 55, 59, 60, 61
Z-Wave Syncing - assigning return route to "047 - Doorbell In"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smart Implant (FGBS222) - 05021000
Z-Wave Syncing - retrieved protocol version 6.02, app version 5.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 31v11 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01), 5:(10 : 01), 6:(10 : 01), 7:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F], 5:[5E 25 85 8E 59 75 6C 22 98 9F], 6:[5E 25 85 8E 59 75 6C 22 98 9F], 7:[5E 85 8E 59 31 71 6C 22 98 9F]
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - added group 1 multi association to interface
Z-Wave Syncing - retrieved parameter 20 "Input 1 type" is 1 "Normally Open"
Z-Wave Syncing - retrieved parameter 40 "Input 1 scene sending" is 0 "None"
Z-Wave Syncing - retrieved parameter 21 "Input 2 type" is 1 "Normally Open"
Z-Wave Syncing - retrieved parameter 41 "Input 2 scene sending" is 0 "None"
Z-Wave Syncing - retrieved parameter 24 "Swap inputs (IN1 and IN2)" is false
Z-Wave Syncing - retrieved parameter 154 "Output 1 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 156 "Output 1 delayed off" is 2 * 0.1 seconds
Z-Wave Syncing - retrieved parameter 155 "Output 2 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 157 "Output 2 delayed off" is 0 * 0.1 seconds
Z-Wave Syncing - retrieved parameter 25 "Swap outputs (OUT1 and OUT2)" is false
Z-Wave Syncing - retrieved parameter 66 "Internal temperature interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 65 "Internal temperature sensitivity" is 5 * 0.1°C
Z-Wave Syncing - device "047 - Doorbell In" parameter 65 "Internal temperature sensitivity" changed to 255 * 0.1°C (was 5 * 0.1°C)
Z-Wave Syncing - retrieved parameter 64 "Analog input interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 63 "Analog input sensitivity" is 0 * 0.1 V
Z-Wave Syncing - retrieved parameter 150 "Analog IN1 debounce" is 10 milliseconds
Z-Wave Syncing - retrieved parameter 151 "Analog IN2 debounce" is 10 milliseconds
Z-Wave Syncing - retrieved parameter 68 "External sensor interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 67 "External sensor sensitivity" is 5 * 0.1
Z-Wave Syncing - device "047 - Doorbell In" parameter 67 "External sensor sensitivity" changed to 0 * 0.1 (was 5 * 0.1)
Z-Wave Syncing - complete
Z-Wave sent "Doorbell In" status request
Z-Wave sent "Doorbell Spare AI 1" status request
Z-Wave received "Doorbell Spare AI 1" sensor update to 10.29 V
Z-Wave sent "Doorbell Spare DI 2" status request
Z-Wave sent "Doorbell Spare AI 2" status request
Z-Wave sent "Doorbell Out" status request
Z-Wave sent "Doorbell Spare DO 2" status request
Z-Wave sent "Doorbell Temperature" status request
Z-Wave received "Doorbell Temperature" sensor update to 32.7 °C
Sun Nov 28, 2021 5:24 pm
Thanks, I found the problem. The UI will be visible to hide logging of the temperature sensor in the next Indigo version.
Sun Nov 28, 2021 11:28 pm
racarter offline
Thanks Matt
Thu Dec 16, 2021 11:58 am
Indigo 2021.2.0 is now available and should now show the UI to hide the temp sensor logging for your Fibaro Smart Implant.
Thu Dec 16, 2021 12:14 pm
racarter offline
Fixed! Thanks Matt.
Mon Jan 10, 2022 7:51 am
wackena offline
I have the Smart Implant fabs-222 with 2 BS18B29 temperature sensors setup and included in v 2021.1. Sensor 1 and Sensor 2 have reported values. The sensor do not auto update sensor values. The only way I've found to update is to create new Schedule using Python script below. Is there another setup way to auto update sensors values, either by value change or time interval?
import time
indigo.device.statusRequest(123, suppressLogging=True)
indigo.device.statusRequest(124, suppressLogging=True)
time.sleep(3)
This code in v2021.1 does not suppress logging. The z-wave "hide the temp sensor logging" feature added to v 2021.1 hides the status request results in the server log, but not the initial "sent "049 - Sensor 1" status request"
Tue Jan 11, 2022 3:41 pm
In the device settings UI how are External sensor interval and External sensor sensitivity defined? Also re-sync and copy/paste the Event Log window results into a reply for me.
