Micro On/Off 2443-222 as 240 Volt Load Controller
Tue Nov 16, 2021 1:11 am
RDLSAT offline
My Insteon 2477SA 30A Load Controller bit the dust and is no longer available. I replaced it with the following items installed into the 2477SA enclosure.
Insteon Micro On/Off 2443-222
240V 40A Contactor w/120V coil
120V 18A SPDT Relay w/120V coil
Momentary Contact Pushbutton N/O
2 x 120V LED Panel Lights
Does anyone know if there is a way to keep the 2443-222 from responding to the All Lights Off (Light/Appliance Controls) command?
It seems that Indigo recognizes the Micro On/Off switch as a light switch rather than an appliance module.
Video Link > https://drive.google.com/file/d/1enUqlu ... sp=sharing
New Components (low-res).jpg (448.81 KiB) Viewed 2597 times
Before-After (low-res).jpg (445.47 KiB) Viewed 2600 times
Wed Nov 17, 2021 5:10 pm
Re: Micro On/Off 2443-222 as 240 Volt Load Controller
Can you copy/paste an Event Log window example of it responding to All Lights Off? Based on the device definition it should turn off for All Off but not All Lights Off.
Thu Nov 18, 2021 12:18 pm
RDLSAT offline
Attached images of Event Trigger and Event Log...
Event Trigger (low-res).jpg (399.35 KiB) Viewed 2522 times
Event Log (low-res).jpg (370.91 KiB) Viewed 2522 times
Thu Nov 18, 2021 3:22 pm
Thanks – I found the problem. I'm going to modify the device definition for this module in Indigo to ignore the All Lights On/Off commands. Can you re-sync the device in Indigo (via its Device dialog) and copy/paste the Event Log result into a reply for me? I want to make sure I modify the correct definition.
Thu Nov 18, 2021 8:53 pm
RDLSAT offline
I re-synced the device as requested but it is still responding to the All Lights Off command...
Event Log (low-res).jpg (325.44 KiB) Viewed 2487 times
Sat Nov 20, 2021 12:13 pm
The device definitions are part of the Indigo app, so my changes to fix the problem won't be available until the next version of Indigo is released.
I was interest in seeing the Event Log window sync results so I could make sure I'm editing the correct definition, but I've double-checked and I'm pretty sure I have identified it (so don't need the sync results).
