- Added support for a new Hue Still Ceiling light.
- Added support for 2 new Hue color pendant lights.
- Added support for a new Hue dimmable light.
reugster wrote:HI Nathan,
I have a few more bulbs to add. Let me know if you need anything else.
LCA005 800 White and Color
Got response {u'1': {u'swversion': u'1.76.11', u'name': u'Hue color lamp 1', u'swupdate': {u'state': u'readytoinstall', u'lastinstall':
u'2021-11-09T00:08:40'}, u'productid': u'Philips-LCA005-1-A19ECLv7', u'uniqueid': u'00:17:88:01:0b:63:1b:18-0b', u'capabilities': {u'control': {u'ct':
{u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'},
u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 6866, u'colormode': u'hs',
u'effect': u'none', u'alert': u'select', u'xy': [0.5516, 0.4134], u'reachable': True, u'mode': u'homeautomation', u'bri': 84, u'ct': 500, u'sat': 254},
u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FC478E3A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode':
u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA005'}, u'3': {u'swversion': u'1.76.11',
Korey wrote:reugster wrote:HI Nathan,
I seem to have the same model (LCA005) not showing up in the plugin.
Except there is no 800 in the bulb info.
indigo2200 wrote:HI, thanks for this wonderful plug-in.
Does the plug-in support Innr SP 220 zigbee smart plug OR the Ikea Trådløs wall-plug??
Nov 10, 2021 at 8:21:05 AM
Stopping plugin Hue Lights (pid 94162)
Stopped plugin Hue Lights
Upgrading plugin Hue Lights to newer version 1.7.60 (previous version moved to trash)
Loading plugin "Hue Lights 1.7.60"
Starting plugin "Hue Lights 1.7.60" (pid 94270)
Hue Lights Error Error in plugin execution InitializeMain:
File "plugin.py", line 33, in <module>
SyntaxError: ('invalid syntax', ('/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/Hue Lights.indigoPlugin/Contents/Server Plugin/supportedDevices.py', 270, 440, "kAmbianceDeviceIDs = ['LLM010', 'LLM011', 'LLM012', 'LTW001', 'LTC001', 'LTC003', 'LTC002', 'LTC003', 'LTW004', 'LTC011', 'LTW010', 'LTW011', 'LTW012', 'LTW013', 'LTW014', 'LTW015', 'LTE001', 'LTF001', 'LTF002', 'LTG001', 'LTG002', 'LTD001', 'LTD002', 'LTP001', 'LTP002', 'LTP003', 'LTP004', 'LTP005', 'LTD003', 'LTD009', 'LTD010', 'LTD011', 'LFF001', 'LTT001', 'LDT001', 'LTB002', 'LTA001', 'LTA002', 'LTA003', 'LTA008', 'LTA010'. 'HML001', 'HML002', 'HML003', 'HML004', 'HML005', 'HML006', '3402931P7', '3261330P6', 'Classic A60 TW', 'PAR16 50 TW', 'RS 128 T', 'RS 228 T', 'FLOALT panel WS 30x90', 'FLOALT panel WS 30x30', 'FLS-CT', 'TRADFRI bulb E26 WS opal 1000lm', 'TRADFRI bulb E27 WS opal 1000lm', 'TRADFRI bulb E27 WS opal 980lm', 'TRADFRI bulb E14 WS opal 600lm', 'TRADFRI bulb GU10 WS 400lm', 'ZBT-ColorTemperature', 'TS0502A', 'MR16 TW OSRAM']\n"))
Stopping plugin "Hue Lights 1.7.60" (pid 94270)
Stopped plugin "Hue Lights 1.7.60"
nsheldon wrote:Version 1.7.61 Posted
- Fixed a syntax error bug in version 1.7.60 that caused the plugin to crash during loading.
