devices:
Office Ceiling Fan Lights:
bridge_type: InsteonLight
Office Credenza Lights:
PeterGlyn wrote:I can select a number of z wave devices to appear in Home Assistant but as I use a number of Virtual Devices I have tries to add some of these as well.My issue is that I only ever see one Virtual device on Home Assistant, usually the last one I have selected.
HassBridge Connecting to the MQTT Server...
HassBridge Error Connection Refused when connecting to broker.
HassBridge Error Exception trapped:HTTPSConnectionPool(host='10.1.1.30', port=8123): Max retries exceeded with url: /api/states (Caused by SSLError(SSLError(1, u'[SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:727)'),))
HassBridge Error Error in plugin execution UiClosed1:
File "plugin.py", line 157, in closedPrefsConfigUi
File "plugin.py", line 137, in _update_perfs
File "plugin.py", line 361, in _setup_ha_devices
File "plugin.py", line 480, in _refresh_ha_info
File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/libs/requests/api.py", line 61, in request
File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/libs/requests/sessions.py", line 530, in request
File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/libs/requests/sessions.py", line 643, in send
File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/libs/requests/adapters.py", line 514, in send
SSLError: HTTPSConnectionPool(host='10.1.1.30', port=8123): Max retries exceeded with url: /api/states (Caused by SSLError(SSLError(1, u'[SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:727)'),))
