Battery & UPS Monitor plugin.
Tue Jan 28, 2020 7:08 am
Re: Battery & UPS Monitor plugin.
I posted a link to a fixed version of this plugin in another thread.
https://github.com/FlyingDiver/Indigo-U ... /tag/1.0.5
Tue Jan 28, 2020 7:44 am
McJohn offline
Thanks for the quick response and the update!
- Maybe it's an idea to post this version into the Plugin Store?
- There is something strange going on with the version numbers and the upgrade message from Indigo.
We have version 1.03. (Installed ~ 2014)
Logical is your number 1.05 a higher number (learned at school :D )
But the message in Indigo is:
Screenshot 2020-01-28 at 14.39.33.png (52.25 KiB) Viewed 13648 times
Tue Jan 28, 2020 8:17 am
I'll have to talk to Matt and Jay about replacing the store version. It's not my plugin, so I can't just update the existing one.
I also have no idea why you're getting that error. The version number increment seems to be correct.
Tue Jan 28, 2020 11:13 am
McJohn offline
Just did some different tests: without and with power available.
Works perfect and Triggers are firing smoothly without any errors anymore!
You did a good job and it's definitely plugin store ready!
Thanks! :D
Tue Sep 08, 2020 3:51 pm
agame offline
I'm not sure if this is the right location for this post but it is UPS related.
Currently experiencing a lot of storms (and associated power outages) so have added a UPS that had fallen into disuse to a Mac mini /Indigo server. Running Catalina.
But whereas after a 'dirty' shutdown the Mac will auto restart when power returns; after a 'clean' (UPS-initiated) shutdown, it requires a manual reboot. Obviously it will ultimately return after the daily restart schedule, but thats less than ideal.
Is there a way to overcome this (other than allowing a dirty shutdown?).
Tue Sep 08, 2020 3:56 pm
Not that I know of. I've done some searching on the topic, and never came up with a solution I thought was reliable.
Get a bigger UPS. :)
Tue Sep 08, 2020 4:00 pm
agame offline
damn!
ha! I actually bought a generator yesterday, that should give a few more hours...
Tue Sep 08, 2020 11:29 pm
2 options:
1. in system prefs set an auto start - that is a fixed time, but you can also set it to eg 1 hours into the future in command line:
use: where the time is 1 hour into the future, run this every 5 minutes
pmset schedule wakeorpoweron "09/08/20 20:00:00"
then when shut down it will try to wake up one hour later
also try acwake, womp
2. set dirty bit: shutdown -u, but that requires to have power off within minutes after successful shutdown, then when UPS power comes back it will restart
not perfect but ..
check out "man pmset" on your mac terminal
But with corona lasting another 6+ months I am not leaving the house any time soon. And we had no long power interruptions in the last year. Only a few secs
==> This is not a priority right now
Sun Jul 25, 2021 12:03 am
Eagleye offline
Joe,
I'm also using this Plug-in, but when I crate a trigger in Indigo, the state comes back as 1000. Do you know what this value represents.
John
Sun Jul 25, 2021 6:08 am
Eagleye wrote:
Joe,
John
Which state? This is not a value sensor, so it doesn't have a default state value.
Screen Shot 2021-07-25 at 8.07.40 AM.png (70.99 KiB) Viewed 12291 times
Wed Apr 12, 2023 2:49 pm
neilk offline
I have done a quick and dirty upgrade to Python 3 for this for my own use, but not sure of the official status and to if I can share (and then how).
Neil
Wed Apr 12, 2023 11:11 pm
MartyS offline
Neil
I'm the most recent maintainer of this plugin, but not having an APC UPS any longer means that I have no good way of testing its action scripts so I chose to see if others wanted/needed the Python 3 upgrade before diving into it myself.
Since you have done it yourself would tell me that it's desired. Please reach out to me in a private message and we'll work something out to get your efforts into the distribution.
/Marty
Thu Apr 13, 2023 10:15 am
neilk offline
Marty,
I did a little more testing on this and was trying to fix one last issue when I realised @flyingdiver has already done the upgrade and the code is in GitHub, it has just never been pushed as a release. I can confirm his version works fine, but it may be good to get this pushed. Note to self: Check the Github before assuming the upgrade has not been done !
Neil
Thu Apr 13, 2023 10:28 am
Yeah, I submitted a PR and the code got merged, but never released. I didn't have permissions to do that.
Thu Apr 13, 2023 10:52 am
MartyS offline
Not certain where you submitted your PR to, but the most recent version that I know of (0.5.2) was mine.
I'd be happy to work with anyone and everyone to get it updated for Python 3.
/Marty
