Visibility to Ecobee Data
SearchCz
Post by SearchCz »
One of my favourite uses of Indigo is to get alerted when something in the home is out of whack. I would like to be able to set up some alerts based on info that my Ecobee thermostat and remote sensor know. I'm specifically looking to tap into things like the current temperature, the set point, the operating mode. Maybe even the motion sensor?
Anyways, it would be great to know what info is available to me, and how I can tap into it. Help?
Re: Visibility to Ecobee Data
Have you set up the Ecobee-2 plugin and looked at the data that's available? All of that is available from the Thermostat device, except the motion sensor, which is presented as it's own (Occupancy) device.
SearchCz
Post by SearchCz »
FlyingDiver wrote:Have you set up the Ecobee-2 plugin and looked at the data that's available? All of that is available from the Thermostat device, except the motion sensor, which is presented as it's own (Occupancy) device.
Where would I “look at the data that’s a available” ? Is the object model documents, or browse-able ?
Generally easiest to look at the available states in a trigger definition. Like this:
Screen Shot 2021-06-30 at 6.55.13 AM.png (658.37 KiB) Viewed 4643 times
There's also some custom states:
Screen Shot 2021-06-30 at 6.55.49 AM.png (130.65 KiB) Viewed 4643 times
SearchCz
Post by SearchCz »
FlyingDiver wrote:Generally easiest to look at the available states in a trigger definition. Like this:
This is perfect ! I totally skipped looking at "device state" and wrongly looked only at the "plugin" section of trigger type. This should do the trick. Thanks for your help!
Custom plugin triggers are generally only for things that cannot be determined solely from the state values. In most cases, triggering on changes to the device state is sufficient.
SearchCz
Post by SearchCz »
Any idea if there is a way to tell if the thermostat is calling for AUX heat ?
SearchCz wrote:Any idea if there is a way to tell if the thermostat is calling for AUX heat ?
I don't know. None of my HVAC systems have that. And I don't see anything about that specifically in the API docs.
Try this: Force your unit into AUX Heat on, wait for an update, then use the "Write Thermostat Data to Log" menu command. Post that and we'll see if there's any info that's relevant.
Screen Shot 2021-06-30 at 6.06.44 PM.png (371.56 KiB) Viewed 4581 times
SearchCz
Post by SearchCz »
Looks like "hvacMode" has something to say about aux heat ?
Jun 30, 2021 at 9:12:29 PM
   Ecobee 2                        {
    "521725513861": {
        "actualHumidity": 48,
        "actualTemperature": 759,
        "brand": "ecobee",
        "climates": {
            "away": "Away",
            "home": "Home",
            "sleep": "Sleep"
        "currentClimate": "home",
        "desiredCool": 920,
        "desiredFanMode": "auto",
        "desiredHeat": 689,
        "equipmentStatus": "",
        "fanMinOnTime": 0,
        "features": "Home,HomeKit",
        "hvacMode": "auxHeatOnly",
        "internal": {
            "humidity": "48",
            "occupancy": "true",
            "temperature": "804"
        "latestEventType": "hold",
        "modelNumber": "vulcanSmart",
        "name": "Main Floor",
        "remotes": {
            "5WFS": {
                "name": "Downstairs",
                "temperature": "718",
                "thermostat": "521725513861"
   Ecobee 2                        {
    "5WFS": {
Yeah, so Indigo doesn't have a thermostat mode like that, so it's mapped to the standard "heat" mode.
Create an enhancement request issue on GitHub and I'll add a new state with the raw HVAC mode. https://github.com/FlyingDiver/Indigo-Ecobee-2/issues
SearchCz
Post by SearchCz »
FlyingDiver wrote:Yeah, so Indigo doesn't have a thermostat mode like that, so it's mapped to the standard "heat" mode.
will do. thanks!
Added 'hvacMode' custom state:
Screen Shot 2021-07-01 at 1.36.58 PM.png (117.63 KiB) Viewed 4497 times
Which can be used in a trigger:
Screen Shot 2021-07-01 at 1.36.30 PM.png (331.5 KiB) Viewed 4497 times
I need to finish uploading to GitHub and then update the store.
SearchCz
Post by SearchCz »
Working great for me. Thanks again for the help!
SearchCz
Post by SearchCz »
How would I et a look at any f these device state values in a python script ?
SearchCz wrote:How would I et a look at any f these device state values in a python script ?
https://wiki.indigodomo.com/doku.php?id ... vice_state
# get the device
print unicode(dev.states)
Except, you can't use the label in the popup shown a couple posts up. You need the name from the list, or right click on the name in the list and get the python reference.
Return to “Ecobee”
