DaveL17 wrote:Hello all - that should be an easy fix. I'll get a fix out asap.
FlyingDiver wrote:DaveL17 wrote:Hello all - that should be an easy fix. I'll get a fix out asap.
Why did that give an error on 2021.1, and not on 7.5? The 11.4 value should have given an error on either version.
DaveL17 wrote:I have pushed a fix to the Indigo Plugin Store. Version 1.0.13 should take care of the OS version bug.
Fantastic Weather Error Error in plugin execution MenuAction:
File "plugin.py", line 544, in dump_the_json
TypeError: Required argument 'format' (pos 1) not found
Bildhauer wrote:Asking the plugin to write the weather data to file the log shows:
- Code: Select all
Apr 1, 2023 at 8:32:02 AM
Fantastic Weather Error Unable to decode data.
File "plugin.py", line 994, in get_weather_data
parsed_json = json.loads(json_string)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/json/__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 2 column 1 (char 1)
Fantastic Weather Warning Fantastic Weather - Daily cannot determine age of data. Skipping until next scheduled poll.
Fantastic Weather Warning Fantastic Weather - Hourly cannot determine age of data. Skipping until next scheduled poll.
