class SerialGateway:
def __init__(self, plugin, dev):
self.logger = logging.getLogger("Plugin.SerialGateway")
self.dev = dev
self.plugin = plugin
self.connected = False
dev.updateStateOnServer(key="status", value="Disconnected")
dev.updateStateImageOnServer(indigo.kStateImageSel.SensorOff)
self.connSerial = None
self.command = ''
def start(self):
self.logger.info(u"{}: Running Serial Start".format(self.dev.name))
serialUrl = self.plugin.getSerialPortUrl(self.dev.pluginProps, u"serialPort")
self.logger.info(u"{}: Serial Port URL is: {}".format(self.dev.name, serialUrl))
self.connSerial = self.plugin.openSerial(u"Lutron Gateway", serialUrl, 9600, stopbits=1, timeout=2, writeTimeout=1)
if self.connSerial is None:
self.logger.error(u"{}: Failed to open serial port".format(self.dev.name))
self.dev.updateStateOnServer(key="status", value="Failed")
self.dev.updateStateImageOnServer(indigo.kStateImageSel.SensorTripped)
return
except Exception, e:
return
self.connected = True
self.dev.updateStateOnServer(key="status", value="Connected")
self.dev.updateStateImageOnServer(indigo.kStateImageSel.SensorOn)
# Disable main repeater terminal prompt
self.send("#MONITORING,12,2")
# Enable main repeater HVAC monitoring
self.send("#MONITORING,17,1")
# Enable main repeater monitoring param 18 (undocumented but seems to be enabled by default for ethernet connections)
self.send("#MONITORING,18,1")
def stop(self):
self.logger.debug(u"Serial stop called")
if self.connected:
self.connSerial.close()
def poll(self):
if not self.connected:
self.start()
s = self.connSerial.read()
except:
self.logger.error(u"{}: Error reading from serial port".format(self.dev.name))
return
if len(s) > 0:
if s == '\r': # RadioRA 2 messages are always terminated with CRLF
tmp = self.command
self.command = ''
return tmp
self.command += s
def send(self, cmd):
self.logger.debug(u"Sending serial command: %s" % cmd)
cmd = cmd + "\r"
self.connSerial.write(str(cmd))
