- Posted on
Fri Jun 11, 2021 9:21 am
offline
The simple relays (shelly - 1, 1pm, 1L, dimmer, dimmer2, bulb, bulb duo, rgb2 ,smoke, gas, dw, dw2, flood,... ) should all work.
Not the shelly-em and shelly-25 types and not the temp/humidity sensors
They split into parent and child devices = they create 2+ devices
Creating another device from within an indigo create device process is not trivial.
Doing that sequentially within the plugin is much easier.
I could look into a follow on process to create the child devices if they do not exist, AFTER the main device was created.. but only if really needed.
