P15-D24 wrote:I uploaded the latest version of Weatherlink plugin but still get the same error. In Indigo I can see it is receiving the correct data from the weather station.
Any ideas?
Not a clue. I've never tried to use weather data with Siri.
Any ideas?
This is great, just what I was looking for. Have had a VantageVue for awhile now and recently added the WeatherLink Live due to adding sensors for air quality (AirLInk). I've been using WeatherSnoop to send data to Wunderground and others but it does not include air quality data. Is this something you might consider adding?
Davis does not include the ability to send .xml and .jason files via. FTP... adding this would be icing on the cake so as to style ourselves on a website.
Jun 4, 2021 at 10:07:06 AM
WeatherLink Live Known device list:
{'409841': {'type': '3', 'lsid': '409841'}, '409843': {'type': '1', 'lsid': '409843'}, '409842': {'type': '4', 'lsid': '409842'}}
AlaskaDave wrote:The only issue is that it does not include the air quality data, perhaps due to the reason you indicated is that it writes directly to their cloud. I was hoping to find a way to collect all data and then publish a .json file or .xml file that then could be styled for a website rather than using the widgets Davis provides.
Comm(WeatherLink AirLink): 1179749524
WeatherLink Live Shutting down WeatherLink Live
Stopped plugin "WeatherLink Live 0.2.0"
Starting plugin "WeatherLink Live 0.2.0" (pid 63771)
Started plugin "WeatherLink Live 0.2.0"
WeatherLink Live Starting WeatherLink Live
WeatherLink Live WeatherLink Live: Polling WeatherLink Live
WeatherLink Live WeatherLink AirLink: Polling WeatherLink Live
WeatherLink Live Error WeatherLink AirLink: http_poll RequestException: HTTPConnectionPool(host='192.168.1.88', port=80): Max retries exceeded with url: /v1/current_conditions (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x10cccc790>, 'Connection to 192.168.1.88 timed out. (connect timeout=3.0)'))
WeatherLink Live Error WeatherLink AirLink: udp_start() RequestException: HTTPConnectionPool(host='192.168.1.88', port=80): Max retries exceeded with url: /v1/real_time (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x10cccc8d0>, 'Connection to 192.168.1.88 timed out. (connect timeout=3.0)'))
