>>> print a
address : 3cf43295
batteryLevel : None
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
description : alias: dev_mbr_bed_ceiling_fan
deviceTypeId : bondDevice
displayStateId : onOffState
displayStateImageSel : PowerOff
displayStateValRaw : False
displayStateValUi : off
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 887774108
com.flyingdiver.indigoplugin.bondhome : (dict)
SupportsStatusRequest : true (bool)
address : 3cf43295 (string)
bond_type : CF (string)
bridge : ZZBL48314 (string)
off_command : TurnOff (string)
on_command : TurnOn (string)
lastChanged : 2000-01-01 00:00:00
lastSuccessfulComm : 2000-01-01 00:00:00
ledStates : []
model : Bond Device
name : MBR Bed Fan
onState : False
ownerProps : com.flyingdiver.indigoplugin.bondhome : (dict)
pluginId : com.flyingdiver.indigoplugin.bondhome
protocol : Plugin
remoteDisplay : True
states : States : (dict)
subModel : Ceiling Fan
supportsAllOff : False
supportsStatusRequest : True
version : None
FlyingDiver wrote:I'm confused. What buttons are on the remote for the fan? Please list them exactly.
And if you start from fan off, what happens when you push each fan-related button?
Jann wrote:Sorry, Let me more fully explain: I've added images of the setup in Indigo and the remote to this post. When I set up the device in Bond app, I simply hit the "toggle light" button recording it as "Turn on light", the "toggle light" button recording it as "Turn off light", same for fan on a different device in the Bond app. Then I remove the remote from the room so no one can control the fan or light from ANYTHING but either the bond app or Indigo. (Prevents the toggle from being confused in Indigo - to a point).
FlyingDiver wrote:Starting with fan off, using the remote, what happens when you press the L/M/H keys (one at a time). If hitting L turns the fan on low, does hitting the "toggle" button turn it off?
FlyingDiver wrote:Do those speeds show up in the popup for the "On Command"? If so, Create a "Fan Low" device with the low speed as the on command and the toggle as the off command.
