16 Apr 2021 at 22:05:04
MQTT Shims Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 115, in runConcurrentThread
File "plugin.py", line 139, in processMessages
File "plugin.py", line 451, in update
UnicodeDecodeError: 'ascii' codec can't decode byte 0xb0 in position 35: ordinal not in range(128)
MQTT Shims Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
16 Apr 2021 at 22:20:03
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_input_voltage/value, payload: 1.0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_input_voltage/unit, payload: V
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_input_frequency/value, payload: 0.0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_input_frequency/unit, payload: Hz
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_voltage/value, payload: 229.0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_voltage/unit, payload: V
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_frequency/value, payload: 50.0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_frequency/unit, payload: Hz
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_apparent_power/value, payload: 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_apparent_power/unit, payload: VA
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_active_power/value, payload: 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_active_power/unit, payload: W
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_load/value, payload: 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_load/unit, payload: %
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/bus_voltage/value, payload: 355
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/bus_voltage/unit, payload: V
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_voltage/value, payload: 25.22
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_voltage/unit, payload: V
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_charging_current/value, payload: 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_charging_current/unit, payload: A
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_capacity/value, payload: 88
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_capacity/unit, payload: %
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/inverter_heat_sink_temperature/value, payload: 631
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/inverter_heat_sink_temperature/unit, payload: °C
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/pv_input_current_for_battery/value, payload: 0.0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/pv_input_current_for_battery/unit, payload: A
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/pv_input_voltage/value, payload: 0.0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/pv_input_voltage/unit, payload: V
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_voltage_from_scc/value, payload: 25.33
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_voltage_from_scc/unit, payload: V
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_discharge_current/value, payload: 1
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/battery_discharge_current/unit, payload: A
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_sbu_priority_version_added/value, payload: 1
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_sbu_priority_version_added/unit, payload: True - 1/False - 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_configuration_changed/value, payload: 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_configuration_changed/unit, payload: True - 1/False - 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_scc_firmware_updated/value, payload: 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_scc_firmware_updated/unit, payload: True - 1/False - 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_load_on/value, payload: 1
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_load_on/unit, payload: True - 1/False - 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_battery_voltage_to_steady_while_charging/value, payload: 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_battery_voltage_to_steady_while_charging/unit, payload: True - 1/False - 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_charging_on/value, payload: 0
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_charging_on/unit, payload: True - 1/False - 0
Reloading plugin "MQTT Connector 0.4.10"
Stopping plugin "MQTT Connector 0.4.10" (pid 1746)
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_scc_charging_on/value, payload: 0
MQTT Connector Debug MQTT Inverter: Removing Trigger
MQTT Connector Battery Inverter: Stopping Device
MQTT Connector Battery Inverter: Disconnecting
MQTT Connector Debug Battery Inverter: processReceivedMessage: QPIGS/status/is_scc_charging_on/unit, payload: True - 1/False - 0
Stopped plugin "MQTT Connector 0.4.10"
Starting plugin "MQTT Connector 0.4.10" (pid 1749)
MQTT Connector Debug MQTT Connector: logLevel = 10
Started plugin "MQTT Connector 0.4.10"
MQTT Connector Starting MQTT Connector
MQTT Connector Battery Inverter: Starting Device
MQTT Connector Debug Battery Inverter: Broker __init__ address = 192.168.1.81, port = 1883, protocol = 4, transport = tcp
MQTT Connector Debug MQTT Inverter: Adding Trigger
MQTT Connector Debug Battery Inverter: Connected with result code 0
MQTT Connector Battery Inverter: Subscribing to: QPIGS/status/# (0)
16 Apr 2021 at 22:18:49
Reloading plugin "MQTT Shims 0.5.1"
Stopping plugin "MQTT Shims 0.5.1" (pid 1605)
MQTT Shims Shutting down MQTT Shims
Stopped plugin "MQTT Shims 0.5.1"
Starting plugin "MQTT Shims 0.5.1" (pid 1741)
Started plugin "MQTT Shims 0.5.1"
MQTT Shims Starting MQTT Shims
Z-Wave received "Hot Water Cylinder - Low Level Sensor" sensor update to 14.25 °C
Z-Wave received "Hot Water Cylinder - High Level Sensor" sensor update to 60.25 °C
Z-Wave received "Hot Water Cylinder - Mid Level Sensor" sensor update to 64.68 °C
Z-Wave received "Outside Temperature" sensor update to 17.43 °C
Stopping plugin "MQTT Connector 0.4.10" (pid 1606)
Starting plugin "MQTT Connector 0.4.10" (pid 1742)
File "plugin.py", line 132, in processMessages
StandardError: PacketTargetNotConnectedError -- plugin MQTT Connector is not enabled
Z-Wave received "Outside Lights - Luminance" sensor update to 0 lux
16 Apr 2021 at 22:19:29
Stopping plugin "MQTT Connector 0.4.10" (pid 1742)
Starting plugin "MQTT Connector 0.4.10" (pid 1746)
