UnicodeDecodeError: 'ascii' codec can't decode byte 0xb0 in
Fri Apr 16, 2021 3:04 pm
Re: UnicodeDecodeError: 'ascii' codec can't decode byte 0xb0
And, damn, the heat sink is really 620°C? Yikes!
Fri Apr 16, 2021 3:08 pm
mwoodage offline
ok, done that, thank you
getting this error in the log,
16 Apr 2021 at 22:05:04
   MQTT Shims Error                Error in plugin execution runConcurrentThread:
  File "plugin.py", line 115, in runConcurrentThread
  File "plugin.py", line 139, in processMessages
  File "plugin.py", line 451, in update
UnicodeDecodeError: 'ascii' codec can't decode byte 0xb0 in position 35: ordinal not in range(128)
   MQTT Shims Error                plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Screenshot 2021-04-16 at 22.07.30.png (382.23 KiB) Viewed 1834 times
Fri Apr 16, 2021 3:09 pm
What's the actual topic and payload that's triggering the error? You should be able to see that in the debug logs.
Fri Apr 16, 2021 3:21 pm
mwoodage offline
Umm, i can't seem to find the error, this is what comes up in the log, can you see anything?
16 Apr 2021 at 22:20:03
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_input_voltage/value, payload: 1.0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_input_voltage/unit, payload: V
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_input_frequency/value, payload: 0.0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_input_frequency/unit, payload: Hz
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_voltage/value, payload: 229.0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_voltage/unit, payload: V
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_frequency/value, payload: 50.0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_frequency/unit, payload: Hz
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_apparent_power/value, payload: 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_apparent_power/unit, payload: VA
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_active_power/value, payload: 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_active_power/unit, payload: W
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_load/value, payload: 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/ac_output_load/unit, payload: %
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/bus_voltage/value, payload: 355
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/bus_voltage/unit, payload: V
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_voltage/value, payload: 25.22
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_voltage/unit, payload: V
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_charging_current/value, payload: 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_charging_current/unit, payload: A
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_capacity/value, payload: 88
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_capacity/unit, payload: %
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/inverter_heat_sink_temperature/value, payload: 631
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/inverter_heat_sink_temperature/unit, payload: °C
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/pv_input_current_for_battery/value, payload: 0.0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/pv_input_current_for_battery/unit, payload: A
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/pv_input_voltage/value, payload: 0.0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/pv_input_voltage/unit, payload: V
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_voltage_from_scc/value, payload: 25.33
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_voltage_from_scc/unit, payload: V
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_discharge_current/value, payload: 1
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/battery_discharge_current/unit, payload: A
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_sbu_priority_version_added/value, payload: 1
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_sbu_priority_version_added/unit, payload: True - 1/False - 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_configuration_changed/value, payload: 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_configuration_changed/unit, payload: True - 1/False - 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_scc_firmware_updated/value, payload: 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_scc_firmware_updated/unit, payload: True - 1/False - 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_load_on/value, payload: 1
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_load_on/unit, payload: True - 1/False - 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_battery_voltage_to_steady_while_charging/value, payload: 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_battery_voltage_to_steady_while_charging/unit, payload: True - 1/False - 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_charging_on/value, payload: 0
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_charging_on/unit, payload: True - 1/False - 0
   Reloading plugin "MQTT Connector 0.4.10"
   Stopping plugin "MQTT Connector 0.4.10" (pid 1746)
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_scc_charging_on/value, payload: 0
   MQTT Connector Debug            MQTT Inverter: Removing Trigger
   MQTT Connector                  Battery Inverter: Stopping Device
   MQTT Connector                  Battery Inverter: Disconnecting
   MQTT Connector Debug            Battery Inverter: processReceivedMessage: QPIGS/status/is_scc_charging_on/unit, payload: True - 1/False - 0
   Stopped plugin "MQTT Connector 0.4.10"
   Starting plugin "MQTT Connector 0.4.10" (pid 1749)
   MQTT Connector Debug            MQTT Connector: logLevel = 10
   Started plugin "MQTT Connector 0.4.10"
   MQTT Connector                  Starting MQTT Connector
   MQTT Connector                  Battery Inverter: Starting Device
   MQTT Connector Debug            Battery Inverter: Broker __init__ address = 192.168.1.81, port = 1883, protocol = 4, transport = tcp
   MQTT Connector Debug            MQTT Inverter: Adding Trigger
   MQTT Connector Debug            Battery Inverter: Connected with result code 0
   MQTT Connector                  Battery Inverter: Subscribing to: QPIGS/status/# (0)
Fri Apr 16, 2021 3:23 pm
I don't see the error in that log segment at all. You'll want to post a dozen of so lines immediately before that error is reported.
Also not sure why you restarted the Connector plugin.
Fri Apr 16, 2021 3:24 pm
mwoodage offline
the only lines before that are below,
16 Apr 2021 at 22:18:49
   Reloading plugin "MQTT Shims 0.5.1"
   Stopping plugin "MQTT Shims 0.5.1" (pid 1605)
   MQTT Shims                      Shutting down MQTT Shims
   Stopped plugin "MQTT Shims 0.5.1"
   Starting plugin "MQTT Shims 0.5.1" (pid 1741)
   Started plugin "MQTT Shims 0.5.1"
   MQTT Shims                      Starting MQTT Shims
   Z-Wave                          received "Hot Water Cylinder - Low Level Sensor" sensor update to 14.25 °C
   Z-Wave                          received "Hot Water Cylinder - High Level Sensor" sensor update to 60.25 °C
   Z-Wave                          received "Hot Water Cylinder - Mid Level Sensor" sensor update to 64.68 °C
   Z-Wave                          received "Outside Temperature" sensor update to 17.43 °C
   Stopping plugin "MQTT Connector 0.4.10" (pid 1606)
   Starting plugin "MQTT Connector 0.4.10" (pid 1742)
  File "plugin.py", line 132, in processMessages
StandardError: PacketTargetNotConnectedError -- plugin MQTT Connector is not enabled
   Z-Wave                          received "Outside Lights - Luminance" sensor update to 0 lux
16 Apr 2021 at 22:19:29
   Stopping plugin "MQTT Connector 0.4.10" (pid 1742)
   Starting plugin "MQTT Connector 0.4.10" (pid 1746)
Fri Apr 16, 2021 3:26 pm
You're going to have to wait until you get the error again, I guess.
And please use CODE tags, not QUOTE.
Fri Apr 16, 2021 3:27 pm
mwoodage offline
Yep ok - i'll keep a look out and post when i see it next. Need to go to bed now, it's getting late here!
Thanks for all your help this evening :D :D
Martin
