Action Group Start cleaning
iRobot-Roomba Debug startRoombaAction for Roomba - Top: Action : start
iRobot-Roomba Debug connecting Roomba Device: Roomba - Top
iRobot-Roomba Debug Using config file: /Users/dlorenz/Documents/Indigo-iRobotRoomba/192.168.178.1
iRobot-Roomba Debug CONTINUOUS connection
iRobot-Roomba Debug Reading Config File: 192.168.178.142-config.ini
iRobot-Roomba Debug Reading config file... /Users/dlorenz/Documents/Indigo-iRobotRoomba/192.168.1
iRobot-Roomba Debug reading info from config file /Users/dlorenz/Documents/Indigo-iRobotRoomba/19
iRobot-Roomba Debug Sections ['192.168.178.142']
iRobot-Roomba Debug Posting DECODED data
iRobot-Roomba Debug Connecting: Top Roomba : 192.168.178.142 : :1:1616662260:ejtcWX5r4nn5KghP
iRobot-Roomba Debug Connecting Top Roomba
iRobot-Roomba Debug Selecting the best SSL TLS Settings
iRobot-Roomba Debug s9 iRoomba VERSION: Using Protocol SSLv23
iRobot-Roomba Debug MQTT Client Succesfully setup
iRobot-Roomba Debug Client Connect Running now Top Roomba
iRobot-Roomba Debug Client LoopStart Running now Top Roomba
iRobot-Roomba Debug Roomba Connected Top Roomba
iRobot-Roomba Debug Received COMMAND: start
iRobot-Roomba Debug Publishing Roomba Command : {"command": "start", "time": 1616755560, "initiat
iRobot-Roomba Debug disconnecting Roomba Device: Roomba - Top
iRobot-Roomba Debug {u'state': OrderedDict([(u'reported', OrderedDict([(u'batPct', 100), (u'batte
iRobot-Roomba Debug Disconnected From Roomba Top Roomba
iRobot-Roomba Debug getRoomba Info Running..
iRobot-Roomba Debug getRoombaInfo for Roomba - Top
iRobot-Roomba Debug startRoombaAction for Roomba - Bottom: Action : start
iRobot-Roomba Debug Publishing Roomba Command : {"command": "start", "time": 1616755570, "initiat
iRobot-Roomba Debug disconnecting Roomba Device: Roomba - Bottom
Changes Plugin Restart code given multiple devices- checks every hour and if no connected iRoomba after 4 checks will restart plugin.py.
(Found was needed as often after days -weeks-months of connection something fails at one end or another. Restarting plugin and resetting the iRoomba connection completely was the best fix. Nothing else completely worked)
sudo xattr -rd com.apple.quarantine /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.5/Plugins
iRobot-Roomba Debug Roomba Name:Top Roomba
iRobot-Roomba Debug Roomba Name:Bottom Roomba
iRobot-Roomba Debug Connecting: Bottom Roomba : 192.168.178.74 : :1:1496074962:mVfImUOLM2iVO2NQ
iRobot-Roomba Debug Connection Roomba Error: not all arguments converted during string formatting
iRobot-Roomba Debug Attempting new Connection# 1
iRobot-Roomba Debug Connecting Bottom Roomba
iRobot-Roomba Debug Client Connect Running now Bottom Roomba
iRobot-Roomba Debug Connection Roomba Error: 61
iRobot-Roomba Debug Attempting new Connection# 2
iRobot-Roomba Debug Client LoopStart Running now Bottom Roomba
iRobot-Roomba Debug Publishing Roomba Command : {"command": "start", "time": 1616938253, "initiator": "localApp"}
iRobot-Roomba Debug Roomba Connected Bottom Roomba
iRobot-Roomba Debug Sending Command to myroomba:Bottom Roomba and action:start
iRobot-Roomba Debug Publishing Roomba Command : {"command": "start", "time": 1616938798, "initiator": "localApp"}
Users browsing this forum: FlyingDiver and 4 guests
