Z-wave Door Sensor ZD2102 Error validating fields
Sat Mar 27, 2021 11:40 am
Hackencrash offline
I get the following error whilst configuring a ZD2102 Door/Window Sensor setting the External switch broadcasting from Enabled to Disabled:
parm 001 value is too small (value cannot be less than 1)
Note, I do not get this error when I set this from Disabled to Enabled.
From the manual, parameter 001 is 0 when disabled and 255 when enabled.
I can set this via Z-Wave > Modify Configuration Parameter... and everything works just fine, so this is a form validation error when setting to Disabled.
Sat Mar 27, 2021 12:50 pm
Re: Z-wave Door Sensor ZD2102 Error validating fields
Thanks for pointing out the UI buglet. We'll get it fixed in the next release.
Sat Mar 27, 2021 1:38 pm
Hackencrash offline
Thanks Matt
