gadgetnut wrote:We are getting recurrent error.
- Code: Select all
Error reflector connection test failed: unable to connect to server
Our Reflector URL seems to load reliably. Indigo Touch seems to work reliably. After a fresh restart of Mac Mini, the reflector error seems to go away for a short while.
In addition to the Reflector error we are also experiencing recurring errors with Python scripts that had been working perfectly for 3+ years.
It was suggested to me that the "server closed the connection" could also point to a general networking problem as opposed to a new problem with scripts that have been in place for years.
Where should I direct my attention? What do you suspect is happening if network problems creep in after a restart? Problem at the router or software (reinstall macOS or Indigo?) or possible hardware problem at Mac Mini?
gadgetnut wrote:As we deliberate if it is our Python scripts that need a structural revision, I wanted you to know that when I first remote logged into this Mac Mini to try your script, Safari or Chrome could not load the webpage on the LAN for the Somfy web server, 192.168.1.73. I tried to load the router at 192.168.1.1 and that wouldn't load either. We restarted the Mac Mini, then the Somfy webpage did load and your revised script did work.
gadgetnut wrote:Yep, I'd like to start a new thread on Starlink Indigo. Perhaps Matt or Jay could tell me the best place to post?
Error Unable to authenticate with IndigoDomo.com (server might be down temporarily for maintenance).
