Hue Lights discussion
Thu Mar 04, 2021 7:31 am
CliveS offline
Re: Hue Lights discussion
bbruck wrote:
Nathan - I downloaded the zip file for 1.7.45 but when I double click on it, the file that opens is the version dated 12/9, which might be 1.7.44.
Well I have just downloaded it and get
4 Mar 2021 at 13:29:00
   Stopping plugin Hue Lights (pid 17983)
   Stopped plugin Hue Lights
   Upgrading plugin Hue Lights to newer version 1.7.45 (previous version moved to trash)
   Loading plugin "Hue Lights 1.7.45"
   Starting plugin "Hue Lights 1.7.45" (pid 91044)
   Started plugin "Hue Lights 1.7.45"
   Hue Lights                      Loaded 14 lights.
   Hue Lights                      Loaded 16 groups.
   Hue Lights                      Loaded 51 scenes.
   Hue Lights                      Loaded 2 sensors.
CliveS
Thu Mar 04, 2021 10:32 am
nsheldon offline
Uh oh. Thanks for letting me know. I’ll get that fixed.
Thu Mar 04, 2021 10:34 am
nsheldon offline
I’ll still double check just to be sure. Thanks.
Fri Mar 05, 2021 4:37 am
bbruck offline
The correct one downloaded today; dunno if you changed something or if I was making a mistake but thanks either way.
Fri Mar 05, 2021 4:46 am
bbruck offline
Nathan - still no joy. When I attempt to recall a scene I see only one scene creator, and only one scene named New, which is not a scene on my Hue app. I also see the following error:
Mar 5, 2021 at 5:39:56 AM
Hue Lights Error Error in plugin execution GetUiDynamicList:
File "plugin.py", line 4771, in scenesListGenerator
KeyError: (u'9d9df6aa-4a9d-4ab6-91da-e8d12a179435',)
Do you need a log file?
Sun Mar 07, 2021 5:02 pm
nsheldon offline
Hi again.
Hmmm... Looking over the code in the plugin, I believe I fixed something else but overlooked the issue that's causing this error. Sorry about that. I've identified what I missed and will fix it in the next patch which should be out soon. I'm also working on fixing a preset issue. Once I get both resolved I'll release 1.7.46 to fix this.
Sun Mar 07, 2021 7:38 pm
nsheldon offline
Version 1.7.46 Posted
  • Fixed a bug that would cause an error when recalling a Hue scene if the scene creator had been deleted via the Hue web site (2nd attempt).
  • Fixed saving and recalling Presets to be compatible with Hue Group devices as both source and target for Preset data.
Wed Mar 10, 2021 9:49 am
bbruck offline
That did it! Thanks so much!!!
Wed Mar 10, 2021 11:05 am
nsheldon offline
Excellent! I'm glad that fixed it.
Wed Mar 24, 2021 12:54 am
nsheldon offline
Version 1.7.47 Posted
  • Added support for the Hue Single color table light.
  • Added support for a new Hue Dimmer Switch.
  • Added support for the Osram Smart + LED GU5.3 reflector.
  • Added support for 2m and 5m Hue Outdoor Lightstrips.
  • Added support for the Hue Amarant Wall Washer light.
  • Added support for the Hue white candle dimmable bulb.
Wed Mar 24, 2021 2:26 pm
danielw offline
Hello Nathan,
Thank you for a great plugin and most important your constant update of it - marvelous.
I learned about the Gledopto brand via your updates and bought a floodlight version RGB+CCT called GL-FL-005P and it doesnt seems that it was a supported one yet. What data would you need to support it?
Here are some data I found in the debug log:
u'32': {u'swversion': u'V_1_5_H2', u'name': u'Outdoor Backside Tree XL', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2021-03-20T11:29:48'}, u'uniqueid': u'58:8e:81:ff:fe:40:4a:f7-0b', u'capabilities': {u'control': {u'ct': {u'max': 495, u'min': 158}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.2119, 0.6823], u'reachable': True, u'mode': u'homeautomation', u'bri': 0, u'ct': 322, u'sat': 0}, u'manufacturername': u'GLEDOPTO', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'wallspot'}, u'type': u'Extended color light', u'modelid': u'GL-FL-005P'}}
Please let me know if I can provide any additional data to make this work.
Cheers
Daniel
Wed Mar 24, 2021 2:31 pm
nsheldon offline
Hi Daniel.
I’m glad the plug-in has been useful for you. As for adding support, the log excerpt you provided is all I need. I’ll add support in the next update.
Sat Mar 27, 2021 1:56 pm
MarcoGT offline
Is the motion sensor working fine with the plug-in?
Is it possible then to trigger actions based on sensor?
Marco
Sat Mar 27, 2021 3:16 pm
nsheldon offline
Hi Marco.
All the Hue branded motion sensors that I know of work with the plugin and you can trigger actions based on the motion sensor as well as the temperature and light sensors that are built into the Hue motion sensors.
Wed Apr 07, 2021 12:21 am
nsheldon offline
Version 1.7.48 Posted
  • Added support for another GLEDOPTO color and color temperature light.
Page 85 of 103 1 ... 82, 83, 84, 85, 86, 87, 88 ... 103
