Error: "ok not found or status_code:412 not in [200]"
Fri Mar 05, 2021 8:30 am
palantir offline
Hi Karl -
I'm getting 2 identical error messages every 30-40 seconds which seems related to my Controller:
5 Mar 2021 at 15:22:35
   uniFiAP Error                   UNIFI executeCMDOnController  login url:https://192.168.20.10:443/api/auth/login
gives, ok not found or status_code:412 not in [200]
  error: {"data":[],"meta":{"rc":"error","msg":"api.err.LoginRequired"}}
The device on 192.168.20.10 is my Unifi controller.
I have been trying different username/password combinations for Controller, but cannot seem to figure out which username/password needs to be provided in which section of the plugin configuration. Based on this error, could you point me what's causing this?
I seem to be getting the devices state from the Controller correctly, so everything seems to work, despite this error message (that's filling up my logging now...).
Many thanks,
Ronald
Sun Mar 07, 2021 9:31 am
Re: Error: "ok not found or status_code:412 not in [200]"
Could you email me (karlwachs at me com)
Menu/ print config
That contains the userids and passwords,
Ports, ip number etc.
don’t post.
Karl.
Sun Mar 07, 2021 4:25 pm
palantir offline
It's in your inbox. Thanks!
Ronald
Wed Mar 10, 2021 10:20 am
You need mac os 10.14 to run the new functionality
In order to connect to UniFi controller v6.x your mac needs to support ssl/tsl 1.1 security layer for python request and Mac OS 10.13 and lower does not come installed with it.
The unifi controller v6.v rejects connections with the outdated security versions.
I have not figured out how to use curl to connect to v6.x which you can use to connect to v5.x. Curl comes with its own security modules which would do the trick.
you can still use the existing functions for up/down info for Ip devices querying the wifiap and switches and gateway directly.
It does
Tail -f /var/log/messages
To get instantaneous changes
And
mca-dump
Every minute to get the whole dB form these devices
To switch off the controller queries in config
Set controller to off
Set controller Ip to blank
Set controller userid to blank.
(The first one should be sufficient ...)
Sent from my iPhone using Tapatalk hi
Wed Mar 17, 2021 9:10 am
palantir offline
Thanks Karl -
Since my server is on 10.13.6, I have made disabled the Controller polling. That made the error message go away indeed.
Many thanks!
Ronald
