With the latest update to the unifi plugin, I am getting DICT timeout errors that don't make sense to me. I have tried increasing the DICT timeout to 2mins (the max) with no result.
Any thoughts?
Stew
Starting plugin "uniFiAP 7.34.317" (pid 66730)
uniFiAP initializing ...
uniFiAP path To files: =================
uniFiAP indigo /Library/Application Support/Perceptive Automation/
uniFiAP installFolder /Library/Application Support/Perceptive Automation/Indigo 7.5/
uniFiAP plugin.py /Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
uniFiAP Plugin params /Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Plugins/com.karlwachs.uniFiAP/
uniFiAP logger enabled for INFO ==> TEST ONLY
uniFiAP Warning logger enabled for WARNING ==> TEST ONLY
uniFiAP Error logger enabled for ERROR ==> TEST ONLY
uniFiAP Error logger enabled for CRITICAL ==> TEST ONLY
uniFiAP check /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log <<<< for detailed logging
uniFiAP Plugin short Name UniFi
uniFiAP my PID 66730
uniFiAP set params for indigo V 7.5
Started plugin "uniFiAP 7.34.317"
uniFiAP testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
uniFiAP myLogSet setting parameters -- logFileActive= ; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Plugins/com.karlwachs.uniFiAP/plugin.log; debugLevel= []
uniFiAP MAP2Vendor initializing
uniFiAP MAP2Vendor initializing finished, read from mac2Vendor.json file
uniFiAP Error Connection: in Line 4487 has error=global name 'dataDictSTR' is not defined Connection
uniFiAP start runConcurrentThread, initializing loop settings and threads ..
uniFiAP initialized ... looping
e
Trigger Weather Temp Variable Update
uniFiAP Error in Line 7071 has error=No JSON object could be decoded
uniFiAP .. in receiving DICTs for APdict-192.168.0.14; for details check unifi logfile at: /Library/Application Support/Perceptive Automation/Indigo x.y/Logs/com.karlwachs.uniFiAP/plugin.log;
uniFiAP .. in receiving DICTs for APdict-192.168.0.15; for details check unifi logfile at: /Library/Application Support/Perceptive Automation/Indigo x.y/Logs/com.karlwachs.uniFiAP/plugin.log;
uniFiAP Error in Line 7093 has error=tuple index out of range
uniFiAP Warning getMessages: stopping listener process for :APdict - 192.168.0.14
uniFiAP Warning getMessages: stopping listener process for :APdict - 192.168.0.15
Trigger Weather Wind Variable Update
File "plugin.py", line 2600, in setfilterunifiCloudKeyListOfSiteNames
NameError: global name 'refreshCallbackMethodAlreadySet' is not defined
uniFiAP Error Error in plugin execution UiAction:
uniFiAP Warning getunifiOSAndPort bad return from unifi controller 192.168.0.5, no os and / port found, tried ports:['443', '8443']
uniFiAP Error exception in deviceStartComm(UniFi: Garage Door Opener): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Granny's iPhone): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Majbritt's iPhone): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Nest Doorbell Camera): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Nest Protect 1): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Nest Protect 2): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Nest Protect 3): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Nest Protect 4): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Nest Protect 5): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Nest Side Yard Camera): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Nintendo Switch): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Stew's Cirrus iPad): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Stew's iPadMini): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Stew's iPhone): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Stew's Work Computer): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Teagan's Echo): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Teagan's iPhone): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi: Teagans iMac): tuple index out of range
uniFiAP Error exception in deviceStartComm(Unifi: WAP-Bedrooms): tuple index out of range
uniFiAP Error exception in deviceStartComm(Unifi: WAP-Kitchen): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_16:47:1e:d8:78:f3): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_18:e8:29:91:dd:9e): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_18:e8:29:92:dd:9e): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_1c:f2:9a:41:af:f9): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_44:61:32:e1:4f:91): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_58:bd:a3:f0:cd:f2): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_5e:ce:3a:ad:a5:8d): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_64:16:66:da:97:e7): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_7a:9c:1a:f0:bb:ab): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_7e:bc:5f:41:26:bb): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_86:1e:eb:8f:ac:22): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_96:9f:eb:92:15:c9): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_98:60:ca:53:c5:4f): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_b0:02:47:b0:ce:89): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_b4:fb:e4:44:42:cc): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_b4:fb:e4:45:42:cc): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_c2:48:6b:cf:6a:96): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_c8:d0:83:e5:57:b8): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_ec:5c:68:25:aa:81): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_fe:bb:d8:7d:0c:6d): tuple index out of range
uniFiAP Error exception in deviceStartComm(UniFi_fe:dc:d5:7a:20:82): tuple index out of range
curl --insecure -I https://192.x.x.x:8443
curl --insecure -I https://192.x.x.x:443
curl --insecure -I https://192.168.1.53:8443
HTTP/1.1 302
Transfer-Encoding: chunked
Date: Wed, 03 Feb 2021 21:38:38 GMT
venus:/Users/stewadmin> curl --insecure -I https://192.168.0.5:8443
HTTP/1.1 302
Date: Wed, 03 Feb 2021 22:27:56 GMT
e Automation/
uniFiAP my PID 82264
Started plugin "uniFiAP 7.34.319"
uniFiAP myLogSet setting parameters -- logFileActive= indigo; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log; debugLevel= [u'ConnectionCMD', u'ConnectionRET']
Trigger Weather Heatindex Variable Update
