Just noticed this...
Sun Jan 31, 2021 5:48 pm
jltnol offline
Dave
So I've been doing a bit of spring cleaning in Indigo, and noticed the 7.4 vs 7.5 Chart Save location. So I decided to make that change, but can't. It seems ANY change in the Plugin Config gives me an error message
Matplotlib Error                Error in plugin execution UiValidate:
  File "plugin.py", line 610, in validatePrefsConfigUi
AttributeError: 'int' object has no attribute 'replace'
At first I thought this might be due to my working from the client, and not the server itself, but even when trying to make changes on the server, I can't. Can't change any of the file paths, none of the chart #'s or even the colors. Not sure if I'm doing something wrong but can't change any settings in the plugin config.
Sun Jan 31, 2021 6:20 pm
Re: Just noticed this...
Sorry to hear that you're having trouble. Please try the latest official release (0.8.32) and let me know if you're still having trouble. If you want to try either of the last two pre-releases, that would be okay too. :D
https://github.com/DaveL17/matplotlib/releases
Sun Jan 31, 2021 9:53 pm
jltnol offline
No need to apologize. It wasn't affecting anything except for housecleaning. I downgraded to 0.8.32 and was able to make the changes necessary... and will probably go back to 0.8.38 as it was working just fine as well.
As always.. thanks so much for your help and support.
Mon Feb 01, 2021 5:54 am
Great. Thanks for letting me know. I'll have another look at that section of code and see if there's anything else that needs to be attended to.
