capture / save data to a txt file
Tue Jan 12, 2021 5:26 pm
SMUSEBY offline
I would like to periodically save a device's data to a file. In particular, I would like to record the temperature measured by a device by running a python script every 15 minutes.
I have one line, but don't know where to go next, - and my one line is probably defective.
I'd be very grateful for a suggestion as to the proper coding.
Bob
data.rtf = open('mac_HD ▸ Users ▸ myName ▸ OneDrive ▸ Documents', 'w')
Tue Jan 12, 2021 5:55 pm
Re: capture / save data to a txt file
dev = indigo.devices[1909647006]
data = dev.states['temperature']
with open('/Users/Dave/Downloads/file.txt', 'a') as outfile:
    output = u"{0}, {1}\n".format(indigo.server.getTime(), data)
    outfile.write(output)
You'll need to change the device ID number, the device state name (maybe), and the path to the file.
EDIT: MAY have to change the state name.
Tue Jan 12, 2021 6:04 pm
SMUSEBY offline
Thanks.
Curious - what does "u"{0}, {1}\n" do?
Tue Jan 12, 2021 6:06 pm
That converts all the data to a Unicode string. That will (at least theoretically) handle all kinds of fancy characters and codes--like degree symbols and such.
https://pyformat.info
Tue Jan 12, 2021 6:27 pm
SMUSEBY offline
and {0} & {1} refer to time and data respectively? and "\n" is ?
Tue Jan 12, 2021 6:33 pm
That's right. The '/n' is the new line character. This ensures that the next entry will start on the subsequent line.
Tue Jan 12, 2021 6:34 pm
SMUSEBY offline
very cool. thanks.
Tue Jan 12, 2021 6:43 pm
No problem whatsoever. This is essentially what the Matplotlib plugin CSV Engine device does.
Tue Jan 12, 2021 6:49 pm
SMUSEBY offline
When I test the script below, the file date is changing, but there are no data. Does there need to be a save command?
dev = indigo.devices[883519697]
data = dev.states['state']
with open('/Users/rss/OneDrive/Documents/GBK/G lRm Temp Data.rtf', 'a') as outfile:
Tue Jan 12, 2021 7:14 pm
It's likely that the state is not called 'state'. It's likely called 'temperature' or something similar. (That's also why I edited my post to say that you *may* have to change the state name.)
If you can't figure out the right name, we have more tools at our disposal.
Tue Jan 12, 2021 7:16 pm
SMUSEBY offline
'state' is the name I used to get the temperature with better email. I have forgotten how I came to that, but I suspect you may have helped.
Tue Jan 12, 2021 7:23 pm
Hah! Run this, and let's look at the states.
data = dev.states
indigo.server.log(u"{}".format(data))
Tue Jan 12, 2021 7:33 pm
SMUSEBY offline
lastUpdate : 2021-01-12 14:53:01 (string)
state : 6.2 (real)
temperature : 6.2 (real)
That's curious. Maybe 'real'?
Thinking ahead, instead of '\n', getting a pair of CSV values on one line might be more useful.
Tue Jan 12, 2021 7:58 pm
Real is the type of value that the state contains. What we want is the name of the state. Try this and see what you get:
The output will be a time stamp and the temperature value. If that's not what you want, we can work on the final format once we know it's logging properly.
Tue Jan 12, 2021 9:09 pm
SMUSEBY offline
the only change I made was substituting "temperature' for 'state'.
No change in result - file date is updated, but actual document is blank.
