Stoutjesdijk
Post by Stoutjesdijk »
I started using Grafana to check what's going on with temperatures, setpoints etc. I noticed something odd in a room where I have two radiators with a thermostat on each of them. You can see in the graphs that the left and right radiators (li, re) are at/above 21 degrees, which is the setpoint for the room. But why are the valves still open, and quite far at that?
Screenshot 2021-01-11 at 16.22.33.png (61.16 KiB) Viewed 7211 times
Best regards,
Mark
Trying to tie it all together...
| Indigo | Plex | NAD M33 | Unifi | LG WebOS | Tado | Sonos | SolarEdge | HUE |
siclark
Post by siclark »
Are the plugin devices using the TRV temp or the room temp with external sensors?
Presumably their own by the set point comment.
The valve will learn to an extent what % to be open to ensure the temperature remains constant. Either they have more to learn or one side of the room gets cooler than the other quicker and needs more top up of hot water than the other one?
Stoutjesdijk
The setpoint temperature is the TRV device state.setpointHeat. I have a variable that I set to the desired room temperature. When the variable changes, a python script adjusts both het setpoints to the same value as that variable. Hence, the two setpoints are always equal.
Both thermostats are in a similar place in the room; under one of the two windows. The temperature values are drawn from the TRV device themselves (state.temperature), and the valve comes from the thermostat device itself (a Spirit). The short purple line one the right side (temp sloping upward slightly) indicates the temperature in the center of the room, but that is not relevant in this problem.
(The heat source is controlled by a NEST thermostat that regulates my boiler, and the NEST gets a heat setpoint equal to the highest demanded temperature in the entire house.)
Best regards,
Mark
autolog
Post by autolog »
The valve opening is controlled by the Spirit. So as Simon says, one is calibrating slightly different to the other. :)
siclark
Post by siclark »
Are you using the TRV controller plugin, or just controlling them yourself?
Stoutjesdijk
TRV!
Best regards,
Mark
siclark
Post by siclark »
Look at for much faster the Re TRV responded compared to the Li one. No wonder they use different %.
Set them both too 1% for now and show this chart tomorrow once the room has got cold then reheated.
Stoutjesdijk
Here is a new graph. It is hard to see, but at 11:30 the setpoint was increased to 22C, and at that time the L and R stat temperatures were both about 14C. A separate temperature sensor far away from the window measured about 16C at that time (purple).
The right Spirit, which is located in a corner and with a bunch of boxes surrounding it, is heating up relatively fast. Its temperature settles fairly quickly at the setpoint.
Interestingly, the left Spirit temp and valve colors are cyan and blue. After a short period of 100% valve, the valve closes but after four hours, the temp is still not at the setpoint. It looks like the valve reacts properly to the measured temperatures, but the effect is not as strong as it should be. Maybe this is a case where I should adjust the temperature offset on the Spirit device. I will give it a shot and report back.
EDIT: Actually, the temperature values do not need an offset, as shown by the measurements during the night and early morning.
Screenshot 2021-01-16 at 16.24.41.png (66.46 KiB) Viewed 7098 times
Best regards,
Mark
shapa
Post by shapa »
HI!
Could you please add the "High Load Switch (HE-HLS01)" as a supported device (in a thermostat mode)?
https://www.heltun.com/z-wave-high-load-relay-switch
https://drive.google.com/file/d/1imYiGS ... l8hZm/view
autolog
Post by autolog »
shapa wrote:Could you please add the "High Load Switch (HE-HLS01)" as a supported device (in a thermostat mode)?
Can you do a device print for me (I assume you have it installed)?
To do this:
  • Go to the Indigo main plugin menu, scroll to the bottom and click on Open Scripting Shell
  • enter: print(u'Thermostat Device:\n{0}'.format(indigo.devices[<YOUR DEVICE ID i.e. 12345678>]))
  • Copy and paste the output back as a reply
I will take a look and create a test version for you to try. :)
siclark
Post by siclark »
Hi Jon. The action to overwrite schedule only supports the on/off setting. Is it possible to overwrite with the setpoint style?
autolog
Post by autolog »
Hi Simon,
siclark wrote:The action to overwrite schedule only supports the on/off setting. Is it possible to overwrite with the setpoint style?
In a word, no.
The logic for Setpoint Style hasn't been implemented (yet). It is on my ever expanding to-do list.
If I implement it, it is likely to completely replace the On/Off way of doing things as supporting two methods makes the plugin much more complicated.
Apologies for any confusion. :|
siclark
Post by siclark »
Ah. I have tried to use the set point style and definitely prefer the idea, but had issues so reverted back so I vote you completely replace the old way
Seriously though still very much appreciate what you did here so all good if you rest on your laurels too.
Return to “TRV Controller”
