Version 1.0.19 now available - tested on Big Sur
Mon Dec 21, 2020 8:00 am
vtmikel offline
Version 1.0.9 of the plugin has been lightly tested on Big Sur. Please report if you have any problems. I personally have moved away from using my own built in InfluxDB Server and Grafana Server, for reasons specific to my setup. However I plan to keep the plugin servers up to date. I'll just need a bit of help testing these included servers as I wont be running them beyond simple release tests.
Big Sur prompted with the normal security prompts, but once appoved through the Preferences -> Security pane, I was able to start both servers.
Grafana has also been upgraded to 7.3.6 in this release.
Sun Dec 27, 2020 3:25 pm
farberm offline
Re: Version 1.0.19 now available - tested on Big Sur
only issue is had to open plug-in with control click cuz developer not identified...
Mon Dec 28, 2020 8:39 am
vtmikel offline
Okay thanks. I thought I saw someone post that they had problems, but the post is now deleted. Yes, you'll get security warnings running the plugin because of the server binaries.
