Lidl Silvercrest Zigbee Smart Plug
colinpartridge
Post by colinpartridge »
Just bought a couple of these Smart plugs at the bargain price of £7.99 each. they pair up with the Hue Hub and work with the hue app. Would it be possible to add this device to the hue plugin. the device ID is TS011F, manufacturer _TZ3000_00mk2xzy
cheers
Colin
siclark
Re: Lidl Silvercrest Zigbee Smart Plug
Post by siclark »
Great find! They are cheap indeed. I think I might need to get a couple myself and see if I can get them into zigbee2mqtt as well as the Hue plugin.
nsheldon
Post by nsheldon »
Hi Colin.
Sure. Could you provide a screenshot from the Hue app info showing the details of that device? The "device ID" and manufacturer information aren't details the plugin can use for feature support. I need the "modelid" as found in the Hue Lights debug logs (and usually shown in the device detailed information within the Hue app). Once I have the model ID, I can add support.
Is that an on/off socket or a dimmer socket?
colinpartridge wrote:Just bought a couple of these Smart plugs at the bargain price of £7.99 each. they pair up with the Hue Hub and work with the hue app. Would it be possible to add this device to the hue plugin. the device ID is TS011F, manufacturer _TZ3000_00mk2xzy
cheers
Colin
colinpartridge
Where would I find debug logs in Hue App?
It’s just an on/off socket
Cheers
Colin
PNG image.png (66.34 KiB) Viewed 3426 times
nsheldon
Post by nsheldon »
Hi again Colin.
That screenshot is perfect. Looks like the model ID is the same as the device ID you mentioned. I don't need the debug logs since the screen shot is enough. But if you're still curious, you can enable and disable debug logging by going to the Plugins menu in Indigo then Hue Lights then Toggle Debugging.
I'll add support for that in the next plugin update.
colinpartridge
Perfect thanks Nathan.
colinpartridge
And here's another one to add to the collection...Lidl LivarnoLux Led Bulb.
Lidl LivarnoLuxBulb.jpg (68.03 KiB) Viewed 3320 times
nsheldon
Post by nsheldon »
No prob. I'll add that one too.
nsheldon
Post by nsheldon »
Version 1.7.42 Posted
  • Added support for a new GLEDOPTO light.
  • Added support for an Ikea FLOALT 30x30 color temperature light panel
  • Added support for the Hue Gradient Lightstrip.
  • Added support for the Lidl smart plug.
  • Added support for the Lidl LivarnoLux Led color temperature bulb.
Locked
Return to “Archives”
