Ring Security Alarm support?
Tue Dec 01, 2020 1:32 pm
Ramias offline
My DSC alarm is getting a bit old. Just saw Ring has an alarm panel AND a retrofit kit to take advantage of existing wired door and window sensors.
I use my Alarm to trigger lights-out events at night, turn on Sonos when I arrive home (specific stations depending on the user code) and to set the Nest thermostat to Away/some lights out when I leave, lock the doors etc.
I could probably do some of this (the home/away) with my iPhone or Apple Watch network detection.
But I'm seriously looking at moving to the Ring alarm panel instead of my DSC/Envisalink 4 setup.
Wondering if this plugin does or could support the Ring alarm panel; either for sensor status or for home/away/armed/disarmed/disarmed by whom settings.
Looks like the homebridge folks have figured a lot of it out: https://github.com/dgreif/ring. Don't have the alarm yet - just throwing this question out there to see if anybody else has also thought of getting it to work with Indigo.
Wed Dec 02, 2020 3:59 pm
Ramias offline
Re: Ring Security Alarm support?
FWIW, I installed this in a docker container: https://github.com/tsightler/ring-mqtt
Used FlyingDiver's MQTT Connector and MQTT Shims plugin, Got my Ring Doorbell to alert for 'ding' and 'motion' messages. Means the alarm looks promising for alerting on its sensors. A bit more latency than like a local zwave motion sensor. I need to find out if it reports a unique disarm message based on user code used.
