NOAA plugin has stopped working?
Thu Nov 19, 2020 3:39 pm
larryx10 offline
As of around 9:30 am on 11/19/2020, the NOAA plugin is returning errors. This happened simultaneously in 3 different Indigo installations with 3 different weather stations. The error is:
NOAA Weather Error HTTP error getting station KFMH data: HTTP Error 403: Forbidden
I tested the URL that the plugin uses (http://www.weather.gov/xml/current_obs/KFMH.xml) in Safari, and that also fails. I don't know if this a temporary problem, or NOAA changed the interface.
Thu Nov 19, 2020 4:06 pm
larryx10 offline
Re: NOAA plugin has stopped working?
It looks like I reported this too soon. After failing for about 7 hours, all sites started working again within a few minutes of my post. (Unless NOAA is watching this board?)
Sun Nov 29, 2020 8:55 pm
dherren offline
It is still not working for me here in Vermont.
Mon Nov 30, 2020 7:36 am
jalves offline
I'm using the NOAA Weather Plus plugin and its been working fine here in Central FL. Just updated a few minutes ago (~8:30 am, Monday)
Jeff
Mon Nov 30, 2020 11:16 am
dherren offline
This looks like a NOAA failure. When I go to the national weather service web site for weather for my town it shows "NA" in all fields
<https://forecast.weather.gov/MapClick.php?CityName=Shoreham&state=VT&site=BTV&textField1=43.9&textField2=-73.32&e=0#.X8Uoci2ZMlk>
