I have no idea why I choose that snippet
This is a new one a bit further down in the log, after I restarted the plugin
SQL Logger Debug (u'inactive', u'0', u'0', u'0', u'0', u'120', u'inactive', u'False', u'True', u'False')
SQL Logger Debug DELETE FROM device_history_1703387849 WHERE ts < %s;
SQL Logger Debug ('2017-11-17',)
SQL Logger Debug INSERT INTO device_history_107654000 ("longstatusstring", "timeleftdays", "timelefthours", "timeleftminutes", "timeleftseconds", "timerstartvalueseconds", "timerstatus", "timerstatus_active", "timerstatus_inactive", "timerstatus_paused") VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s);
SQL Logger Debug DELETE FROM device_history_107654000 WHERE ts < %s;
SQL Logger Debug INSERT INTO device_history_1672970085 ("longstatusstring", "timeleftdays", "timelefthours", "timeleftminutes", "timeleftseconds", "timerstartvalueseconds", "timerstatus", "timerstatus_active", "timerstatus_inactive", "timerstatus_paused") VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s);
SQL Logger Debug (u'inactive', u'0', u'0', u'0', u'0', u'3600', u'inactive', u'False', u'True', u'False')
SQL Logger Debug DELETE FROM device_history_1672970085 WHERE ts < %s;
SQL Logger Debug INSERT INTO device_history_751898018 ("longstatusstring", "timeleftdays", "timelefthours", "timeleftminutes", "timeleftseconds", "timerstartvalueseconds", "timerstatus", "timerstatus_active", "timerstatus_inactive", "timerstatus_paused") VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s);
SQL Logger Debug (u'inactive', u'0', u'0', u'0', u'0', u'1200', u'inactive', u'False', u'True', u'False')
SQL Logger Debug DELETE FROM device_history_751898018 WHERE ts < %s;
SQL Logger Debug INSERT INTO device_history_1523305554 ("longstatusstring", "timeleftdays", "timelefthours", "timeleftminutes", "timeleftseconds", "timerstartvalueseconds", "timerstatus", "timerstatus_active", "timerstatus_inactive", "timerstatus_paused") VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s);
SQL Logger Debug (u'inactive', u'0', u'0', u'0', u'0', u'252000', u'inactive', u'False', u'True', u'False')
SQL Logger Debug DELETE FROM device_history_1523305554 WHERE ts < %s;
SQL Logger Error exception trying to insert row into table device_history_1523305554 ("timersPester_tidMellanBuskarSprinkler_70h") -- unable to modify table
SQL Logger Error Connection to backend closed
SQL Logger Error INSERT INTO device_history_1523305554 ("longstatusstring", "timeleftdays", "timelefthours", "timeleftminutes", "timeleftseconds", "timerstartvalueseconds", "timerstatus", "timerstatus_active", "timerstatus_inactive", "timerstatus_paused") VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s);
SQL Logger Error exception trying to create table device_history_1888213338 ("timersPester_tidMellanPlantSprinkler_46h")
SQL Logger Debug INSERT INTO device_history_1888213338 ("longstatusstring", "timeleftdays", "timelefthours", "timeleftminutes", "timeleftseconds", "timerstartvalueseconds", "timerstatus", "timerstatus_active", "timerstatus_inactive", "timerstatus_paused") VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s);
SQL Logger Debug (u'inactive', u'0', u'0', u'0', u'0', u'165600', u'inactive', u'False', u'True', u'False')
SQL Logger Error broken pipe error trying to insert row into table device_history_1888213338 ("timersPester_tidMellanPlantSprinkler_46h")
SQL Logger closing SQL connection
SQL Logger Error exception trying to create table device_history_821779449 ("TP_B-julstjarnor")
SQL Logger Error not connected to database
SQL Logger Debug INSERT INTO device_history_821779449 ("alias", "onoffstate", "rssi") VALUES (%s, %s, %s);
SQL Logger Debug (u'TP_B', u'True', u'-65')
SQL Logger Error exception trying to insert row into table device_history_821779449 ("TP_B-julstjarnor")
SQL Logger Error 'NoneType' object has no attribute 'execute'
SQL Logger Error INSERT INTO device_history_821779449 ("alias", "onoffstate", "rssi") VALUES (%s, %s, %s);
SQL Logger Error exception trying to create table device_history_5481455 ("TP_C julstjarna Sovrum")
SQL Logger Debug INSERT INTO device_history_5481455 ("alias", "onoffstate", "rssi") VALUES (%s, %s, %s);
SQL Logger Debug (u'TP_C', u'True', u'-59')
SQL Logger Error exception trying to insert row into table device_history_5481455 ("TP_C julstjarna Sovrum")
SQL Logger Error INSERT INTO device_history_5481455 ("alias", "onoffstate", "rssi") VALUES (%s, %s, %s);
SQL Logger Error exception trying to create table device_history_1982773061 ("Twilio_Mattias")
SQL Logger Debug INSERT INTO device_history_1982773061 ("contactstatus") VALUES (%s);
SQL Logger Debug (u'',)
SQL Logger Error exception trying to insert row into table device_history_1982773061 ("Twilio_Mattias")
SQL Logger Error INSERT INTO device_history_1982773061 ("contactstatus") VALUES (%s);
SQL Logger Error exception trying to create table device_history_496113970 ("Twilio_nummer9193357864")
SQL Logger Debug INSERT INTO device_history_496113970 ("last_auth", "matchresult", "messagefrom", "messagetext", "messageto", "numberstatus") VALUES (%s, %s, %s, %s, %s, %s);
SQL Logger Debug (u'', u'', u'', u'', u'', u'Message Sent')
SQL Logger Error exception trying to insert row into table device_history_496113970 ("Twilio_nummer9193357864")
