New Plugin - miniUniFi (minimal UniFi access)
Mon Oct 26, 2020 9:55 am
Re: New Plugin - miniUniFi (minimal UniFi access)
autolog wrote:
You could add an option in the Edit device settings to do that if checked.
Alternatively only change it if the current name starts with "new device", so you don't overwrite it if someone has already changed it. :)
I hate adding options. Pretty soon, it's too complicated to deal with.
I'll see if I can figure out a way to not overwrite if the user has already set the name. Maybe I can do it on closing the dialog?
Or maybe it's just a bad idea. ;)
Mon Oct 26, 2020 10:47 am
Doctor Q offline
Got version.10 running by changing port to 443 and no SSL. Looks promising. Pretty good for working without a map, FD.
Mon Oct 26, 2020 10:50 am
Actually, if you have a UDMP the port field is ignored now. SSL Verify requires you have valid SSL certificates installed on the UDMP.
Tue Oct 27, 2020 6:57 am
Colly offline
Hi Joe,
I've set up the plugin and have it working well. I see 2 statuses; first_seen and last_seen. What do the numbers mean? I would see it being beneficial if these were actual times - I know I can resolve by using triggers however it would be good if it was available directly from the plugin.
Rgds
Colly
Screenshot 2020-10-27 at 12.53.20.png (12.42 KiB) Viewed 4028 times
Tue Oct 27, 2020 7:09 am
You need to get the latest version from GitHub. The states have changed a bunch since whatever version you're running.
Those values are Posix timestamp values. They can be converted to an actual time/date string, but what would you use that for?
There's a new state called "offline_seconds" which is probably more useful, as it's the time (in seconds) since the device was last seen by the controller.
Tue Oct 27, 2020 7:12 am
Colly offline
OK - I will check the latest version out, my mistake.
I have some control pages which show when seen on network which I more or less use as the time either my wife of I have left or returned to the house.
Tue Oct 27, 2020 7:33 am
Colly offline
Tried the latest version (0.0.11) - here is the link for others https://github.com/FlyingDiver/Indigo-miniUniFi/releases/tag/0.0.11
The offline seconds can be used for my needs also. I've added a request on GitHub for custom state to display time that client left the Network.
Tue Oct 27, 2020 12:58 pm
Doctor Q offline
I'm running .11 and getting this error, even though it appeared to be working:
miniUniFi Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1165, in deviceUpdated
File "plugin.py", line 597, in didDeviceCommPropertyChange
UnicodeEncodeError: 'ascii' codec can't encode character u'\u2019' in position 2622: ordinal not in range(128)
Tue Oct 27, 2020 1:01 pm
Yeah, I added some code if needed for debugging later, and forgot to make it unicode compatible. It'll be fixed in 0.12, which will probably be available later today.
Tue Oct 27, 2020 1:17 pm
Pre-release version 0.0.12 is now available: https://github.com/FlyingDiver/Indigo-m ... tag/0.0.12
Lots of bug fixes.
A number of enhancements requests have been filed. I encourage all testers to comment on them. And create new ones.
https://github.com/FlyingDiver/Indigo-miniUniFi/issues
Wed Oct 28, 2020 2:05 pm
Hey folks -
I need the 'model' and 'type' states for any UniFi device that's not an AP or switch. Like Protect camera, UDM, or UDMP.
Wed Oct 28, 2020 6:37 pm
Release 0.0.13: https://github.com/FlyingDiver/Indigo-m ... tag/0.0.13
Set UniFi device type and model, issue #13
Fix for off-line controller error, issue #19
Added firmware version to UI for UniFi devices
Get controller SW version
Thu Oct 29, 2020 7:42 am
jalves offline
Just wanted to post that I set up this plugin today and quickly got three devices setup without problem. That's on a UDM and the three devices are two iPhones and an Apple Watch. Haven't yet set up triggers but will be doing so over the next few days. Thanks for your work on this!
Jeff
Thu Oct 29, 2020 8:00 am
Pre-release 0.0.15 now available: https://github.com/FlyingDiver/Indigo-m ... tag/0.0.15
This is getting very close to release status. There are a number of enhancement issues still open that will be considered after official release.
Thu Oct 29, 2020 8:27 am
autolog offline
Installed 0.0.15.
I deleted all my devices and started again. I set up my Cloud Key G2 controller OK.
I then added a switch 8 150W POE and got this error in the Indigo log.
SQL Logger Error exception trying to insert row into table device_history_1825415154 ("new device 2") -- unable to modify table
SQL Logger Error ERROR: value "12934643202" is out of range for type integer at character 14439
SQL Logger Error INSERT INTO device_history_1825415154 ("port_table_5_poe_power" ...
I can PM you the output but don't want to post it to a public forum. :)
btw - I noticed this late last night on a previous version (12?) , so I don't think it is 15 specific.
