Insteon Inline Relay
Sat Aug 08, 2020 1:02 am
pgershon offline
Smarthome seems to have discontinued this product. Any ideas for a replacement?
Sat Aug 08, 2020 10:28 am
Re: Insteon Inline Relay
I'd suggest you look into using Z-Wave. You'll of course need a Z-Wave Controller but once you have one you'll have access to a plethora of new modules. In this case I'd suggest looking at the Aeotec Nano Switch (ZW139) to see if it will work for your needs.
Sun Aug 09, 2020 2:46 am
pgershon offline
Thanks Matt. Looks like the Nanco switch is limited to 5 amps. I believe the Insteon Relay worked up to 20 amps. This is for series of outdoor lights (120 Volt). I am afraid too much current.
Sun Aug 09, 2020 9:30 am
Here is a list of other Indigo compatible (either Z-Wave or ShellyMQTT Plugin) inline relays that might work.
