zigbee2mqtt & zigbee USB for Hue bulbs
Fri Jul 03, 2020 8:41 am
Re: zigbee2mqtt & zigbee USB for Hue bulbs
siclark wrote:
I am finally getting back to these. Looking at the Aqara wireless switches to control the light bulbs. They work great for on/off, and dimming zwave bulbs, but the MQTT color device which is the bulb doesnt appear to support Brighten/Dim By or Start Brightening/Dimming. which I would love be able to use with the hold / release commands from the Aqara wireless switches.
Is that an easy change?
Not sure. I'll take a look.
Fri Jul 03, 2020 9:18 am
Try 0.3.2: https://github.com/FlyingDiver/Indigo-S ... /tag/0.3.2
This has both the brightness/onOffState change requested, and also implements BrightenBy and DimBy. The start/stop commands would require additional templates for the MQTT commands and would be a lot more work.
0.3.X is still pre-release. Let me know if these are stable enough to be released on the Plugin Store.
Fri Jul 03, 2020 10:07 am
siclark offline
Thanks will do.
Brighten by would normally be fine but the hold doesn’t seem to change anything in the mqtt message, ie no time or counter so nothing for the indigo trigger to react to so holding would just trigger once rather than multiple times.
I need to spend a a little more time on these switches.
I can use double click to activate brighten by set amount and that will work. Its much better than what I have today it had with the hue hub
Fri Jul 03, 2020 10:13 am
So does it send a message when you start to hold (press down) and another when you release? If so, there's probably something you could do with repeating timers and a stop timer on the release.
Or maybe a pester device.
Fri Jul 03, 2020 10:25 am
siclark offline
Exactly. Yes I was thinking same. Just a bit more complicated.
Fri Jul 03, 2020 12:31 pm
siclark offline
I am getting this error now
   MQTT Shims Error                Error in plugin execution runConcurrentThread:
  File "plugin.py", line 107, in runConcurrentThread
  File "plugin.py", line 131, in processMessages
  File "plugin.py", line 453, in update
NameError: global name 'state_list' is not defined
   MQTT Shims Error                plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Fri Jul 03, 2020 12:52 pm
Fri Jul 03, 2020 12:58 pm
siclark offline
Thbanks..
On and off work without error now, but get this on Brighten by
   MQTT Shims Error                Error in plugin execution ExecuteAction:
  File "plugin.py", line 904, in actionControlDevice
NameError: global name 'dev' is not defined
Fri Jul 03, 2020 1:30 pm
Thu Jul 09, 2020 5:01 am
siclark offline
Had some issues with the Hue Remote and its taken me a few days to get this working again, so not been playing with the latest version.
Brighten by and dim by are working well now.
I have turned off my hue hub and deleted all the old Hue devices from Indigo as well as my previous devices that used the node-red solution.
I am sure there will be a few more tweaks that could be made but I am happy with how this is working now.
Thanks for your work on this, and its great we can have zigbee devices of all sorts working with Indigo without an expensive hub.
Simon
Mon Dec 14, 2020 4:38 am
siclark offline
Hi Joe,
Apologies, life and work got the better of me over the last few months.
My system is working well generally, but I am still not seeing the on/off state update in Indigo. This applies whether I turn the device on or off with indigo, or set the brightness (to 0 for example) even though mqtt reports the state change.
The full mqtt message is
{"brightness":254,"color":{"x":0.339715260382228,"y":0.347215989076895},"color_temp":192,"linkquality":94,"state":"OFF","update_available":false}
and I have tried setting teh status request payload to this
{"brightness":"","color":{"x":"","y":""},"color_temp":"","linkquality":"","state":"","update_available":""}.  from just having the state
This is from debug turning it on, from off. The bulb responds correctly, but the indigo doesnt change,
 MQTT Shims Debug                Kitchen Pendant 1: processMessages: '##HueBulb##' zigbee2mqtt/HueBulb/Kitchen1 -> {"brightness":254,"color":{"x":0.339715260382228,"y":0.347215989076895},"color_temp":192,"linkquality":94,"state":"OFF","update_available":false}
   MQTT Shims Debug                Kitchen Pendant 1: state = OFF
   MQTT Shims Debug                Kitchen Pendant 1: shimColor, state_key = state, value_key = brightness, data = {u'color_temp': 192, u'linkquality': 94, u'update_available': False, u'brightness': 254, u'color': {u'y': 0.347215989076895, u'x': 0.339715260382228}, u'state': u'OFF'}, state = OFF, value = 254
   MQTT Shims Debug                Kitchen Pendant 1: No brightnessLevel, setting onOffState to False
   MQTT Shims Debug                Kitchen Pendant 1: Updating brightnessLevel to 100
   MQTT Shims Debug                Kitchen Pendant 1: convert_color_space_import input: {u'y': 0.347215989076895, u'x': 0.339715260382228}
   MQTT Shims Debug                Kitchen Pendant 1: xy_to_rgb output: 255 250 232
   MQTT Shims Debug                Kitchen Pendant 1: convert_color_space_import output: {'greenLevel': 98.03921568627452, 'redLevel': 100.0, 'blueLevel': 90.98039215686275}
   MQTT Shims Debug                Kitchen Pendant 1: Updating color values to {'greenLevel': 98.03921568627452, 'redLevel': 100.0, 'blueLevel': 90.98039215686275}
   MQTT Shims Debug                Kitchen Pendant 1: Updating states: [{'value': False, 'key': 'onOffState'}, {'value': 100, 'key': 'brightnessLevel'}, {'value': 100.0, 'key': 'redLevel'}, {'value': 98.03921568627452, 'key': 'greenLevel'}, {'value': 90.98039215686275, 'key': 'blueLevel'}]
   MQTT Shims Debug                Kitchen Pendant 1: Updating color temperature to 5208
However when on and I Set brightness to zero in ingido, the icon does go to off
MQTT Shims Debug                Kitchen Pendant 1: processMessages: '##HueBulb##' zigbee2mqtt/HueBulb/Kitchen1 -> {"brightness":0,"color":{"x":0.339715260382228,"y":0.347215989076895},"color_temp":192,"linkquality":94,"state":"OFF","update_available":false}
   MQTT Shims Debug                Kitchen Pendant 1: shimColor, state_key = state, value_key = brightness, data = {u'color_temp': 192, u'linkquality': 94, u'update_available': False, u'brightness': 0, u'color': {u'y': 0.347215989076895, u'x': 0.339715260382228}, u'state': u'OFF'}, state = OFF, value = 0
   MQTT Shims Debug                Kitchen Pendant 1: Updating brightnessLevel to 0
   MQTT Shims Debug                Kitchen Pendant 1: Updating states: [{'value': False, 'key': 'onOffState'}, {'value': 0, 'key': 'brightnessLevel'}, {'value': 100.0, 'key': 'redLevel'}, {'value': 98.03921568627452, 'key': 'greenLevel'}, {'value': 90.98039215686275, 'key': 'blueLevel'}]
Any ideas? is this an issue in my setup?
Simon
Mon Dec 14, 2020 7:33 am
I need to see the Shim device definitions again. Best is probably to use the "write device template to log" menu command.
Mon Dec 14, 2020 7:36 am
siclark offline
My simple guess at this, but does the state_location_topic_field need changing from 0?
message_type: '##HueBulb##'
props:
    SupportsColor: true
    SupportsRGB: true
    SupportsStatusRequest: true
    SupportsWhite: true
    SupportsWhiteTemperature: true
    action_template: zigbee2mqtt/HueBulb/{{uniqueID}}/set
    brightness_scale: '255'
    color_space: HueC
    color_temp_payload_key: color_temp
    color_temp_scale: Mirek
    color_value_payload_key: color
    dimmer_action_payload: '{"state": "ON", "brightness": {{brightness}} }'
    dimmer_action_template: zigbee2mqtt/HueBulb/{{uniqueID}}/set
    off_action_payload: 'OFF'
    on_action_payload: 'ON'
    rgb_scale: '255'
    set_rgb_template: '{"state":"ON","brightness":{{brightness}},"color":{"x":{{x}},"y":{{y}}}}'
    set_rgb_topic: zigbee2mqtt/HueBulb/{{uniqueID}}/set
    set_temp_template: '{"state":"ON","brightness":{{brightness}},"color_temp":{{color_temp}}}'
    set_temp_topic: zigbee2mqtt/HueBulb/{{uniqueID}}/set
    state_location: payload
    state_location_payload_key: state
    state_location_payload_type: json
    state_location_topic_field: '0'
    status_action_payload: '{"brightness":"","color":{"x":"","y":""},"color_temp":"","linkquality":"","state":"","update_available":""}'
    status_action_template: zigbee2mqtt/HueBulb/{{uniqueID}}/get
    uid_location: topic
    uid_location_topic_field: '2'
    value_location_payload_key: brightness
trigger:
    match_list: '["Match: zigbee2mqtt", "Match: HueBulb", "Any: ", "End: "]'
    queueMessage: true
type: shimColor
Mon Dec 14, 2020 7:44 am
No, because 'state_location' is 'payload' (not topic).
Mon Dec 14, 2020 7:49 am
siclark offline
haha.. ok I will stop my novice debugging then :lol:
Page 6 of 8 1 ... 3, 4, 5, 6, 7, 8
