Converting AppleScript that reads data from remote URL
Mon Jun 29, 2020 10:08 am
gmusser offline
I'm on to my next AppleScript conversion, which retrieves data that one of my environmental sensors uploads to a remote website. The data is returned in an array that looks like this:
{"time": "2019-08-04 10:44:53", "CPM": "19", "ACPM": "18.22", "uSv": "0.12"}
The AppleScript I've been using is:
   --retrieve from GMC Map
   set TheCommand to "curl -m 5 --request GET http://www.gmcmap.com/historyData-plain.asp?Param_ID=68108722812"
   try
      set myResult to do shell script TheCommand
      --extract Geiger reading
      set AppleScript's text item delimiters to ","
      set theArray to every text item of myResult
      set radLevelText to item 2 of theArray
      -- extract value from text string
      set radLevel to word 2 of radLevelText
      set value of variable "Radiation_Basement" to radLevel
   on error
      log "Error executing curl to retrieve from gmcmap.com"
   end try
end tell
Based on examples in the Indigo forums, I tried this Python code:
import requests
import simplejson
# output from gmcmap.com looks like this:
# {"time": "2019-08-04 10:44:53", "CPM": "19", "ACPM": "18.22", "uSv": "0.12"}
result = requests.get("http://www.gmcmap.com/historyData-plain.asp?Param_ID=68108722812")
response = simplejson.loads(result)
indigo.variable.updateValue(385534937, response["CPM"])
But I get this error:
Script Error GMC Map.py: expected string or buffer
GMC Map.py, line 8, at top level
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/__init__.py", line 307, in loads
return _default_decoder.decode(s)
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 335, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
TypeError: expected string or buffer
I'm not sure what to do now. Thanks for your help. It is greatly appreciated!
Mon Jun 29, 2020 10:23 am
Re: Converting AppleScript that reads data from remote URL
Try this for the second to last line:
response = result.json()
The requests library knows how to automatically decode json for you. Your version might have worked if you passed result.text to the simplejson.loads function.
FYI, when using the json library you should:
import json
We included simplejson because when we first released Python support, Python 2.5 was the standard version on Macs and it didn't have the built-in library. If you are still running on a very old Mac OS version (before Yosemite I think) then you should continue to use simplejson.
Mon Jun 29, 2020 10:24 am
FlyingDiver online
The result variable is a complex object containing all the info about the request call. You need:
import requests
import simplejson
response = simplejson.loads(result. text)
But you don't even need to do that much, as requests can do the JSON for you:
import requests
Mon Jun 29, 2020 10:55 am
gmusser offline
Ah, that clarifies matter. But the revised code still give an error that, for a noobie, is incomprehensible:
Script Error GMC Map.py: 'instancemethod' object is not subscriptable
TypeError: 'instancemethod' object is not subscriptable
Mon Jun 29, 2020 10:59 am
FlyingDiver online
Post your complete script. You probably have a typo.
Mon Jun 29, 2020 11:02 am
gmusser offline
It is a direct copy of the above.
Mon Jun 29, 2020 11:03 am
FlyingDiver online
Which one above? There are multiple scripts. And at least one (of mine) has an errant space in it (that I see now).
Mon Jun 29, 2020 11:10 am
gmusser offline
import requests
Mon Jun 29, 2020 11:12 am
FlyingDiver online
Oops. Jay had it right. Should be:
import requests
Mon Jun 29, 2020 11:37 am
gmusser offline
Great, I added the parentheses and an "import json" line. But now I get the following error. I checked the URL and it is properly returning output in the format I mentioned.
 Script Error                    GMC Map.py: No JSON object could be decoded
     GMC Map.py, line 7, at top level
     File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/models.py", line 816, in json
       return complexjson.loads(self.text, **kwargs)
     File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 353, in raw_decode
       raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
Mon Jun 29, 2020 11:41 am
FlyingDiver online
Actually, that URL is returning HTML with a JSON string embedded in it:
jkeenan@Kraken ~ % python
>>> import requests
>>> result.text
u' \r\n\r\n\r\n<!DOCTYPE HTML>\r\n\r\n<html>\r\n  <head>\r\n   <meta charset="utf-8">\r\n\r\n    \r\n\r\n  </head>\r\n  <body>\r\n\r\n        \r\n\r\n\r\n\r\n \r\n\r\n\r\n\r\n\r\n\r\n    <table class="table table-hover">\r\n\r\n     \r\n\r\n    {"time": "2020-06-29 17:39:16",\r\n    "CPM": "24", \r\n    "ACPM": "244.54",\r\n    "uSv": "0.16"}\r\n  \r\n\r\n\r\n\r\n \r\n</table>\r\n\r\n\r\n\r\n\r\n  \r\n\r\n\r\n\r\n\r\n\r\n\r\n  </body>\r\n</html>\r\n\r\n'
That's going to be a lot harder to parse out.
Mon Jun 29, 2020 11:49 am
FlyingDiver online
Yeah, you skipped converting this section of your original script;
import requests
lines = result.text.split(',')
words = lines[1].split(":")
indigo.variable.updateValue(385534937, words[1])
Mon Jun 29, 2020 12:26 pm
gmusser offline
Ahhhh I naïvely thought the parsing would be automatic. One issue remains: the Indigo variable value includes quotation marks. How do I strip them out? This wasn’t an issue with AppleScript. I tried applying strip() but that leaves the leading quote mark. When I run strip() a second time to try to eliminate that quote mark, it remains. The function remove() is no better. Presumably there is some more elegant solution, anyway.
import requests
cpm_value = words[1].strip('"')
cpm_value = cpm_value.strip('"')
indigo.variable.updateValue(385534937, cpm_value)
Mon Jun 29, 2020 12:40 pm
FlyingDiver online
Mon Jun 29, 2020 1:28 pm
gmusser offline
Yes, those are the directions I followed, but it’s not working.
