Fibaro FGR-223
Thu Jun 18, 2020 3:04 pm
Umtauscher offline
Re: Fibaro FGR-223
Matt, Jay
I am very sorry. But I really don‘t agree with what you are implying.
You expect us to provide data for devices you are not supporting so you can (eventually) bring your software up to date.
In exchange for that, we have to pay an annual fee for updates that might come some day.
Additionally you act as if you were doing a good deed if you support the product and expect us to be very grateful for that
I realize I am trapped in this at the moment and should keep quiet.
My initial question is more than a year old. The device in question still isn‘t in the supported list. Others seem to wait for it as well.
Do you really think it would have been worth to buy those devices,, install them and wait until your software might support them?
And if you missed that, I was just answering duriosity’s question and was sort of apologizing that I didn‘t file a device definition.
Never mind, I will keep quiet from now on.
Thu Jun 18, 2020 4:10 pm
durosity offline
Re: Fibaro FGR-223
Oh yikes sorry I’ve hit a bit of a sore spot there!
Don’t worry I’ll go send the details as requested. I’m more than happy to work with ya on getting it added.
I do agree it can be a little frustrating with having to submit first, get it working later.. but I guess with so many modules and so many variants of those modules (and different use cases) it’s probably the only real way for M&J to do it. Especially considering many of the devices submitted won’t even be available for use on US frequencies! So let’s all take a step back and let clearer heads prevail!
Thu Jun 18, 2020 5:13 pm
peszko offline
Re: Fibaro FGR-223
Personally, I don't mind buying modules that are not supported and submitting device definitions when I really need them. I'v done that in the past and recently with Qubino ZMNHID3 (BTW, it mostly works). Nowadays most stores allow returns, so if a device truly doesn't work I can usually return it. (I do test them on the "bench" before going all commando and permanently installing them though) For me, and I assume a lot of Indigo customers, HA is a useful hobby with the understanding that it will require a bit of work (and wife patience). I find that Mat and Jay are super responsive to all the issues I have brought up.
Fri Jun 19, 2020 2:24 am
durosity offline
Re: Fibaro FGR-223
Hey guys I've submitted the details as requested and here's the dump from the log:
Indigo Z-Wave Version: 7.4.1
Node ID: 126
Model: Motor Control Class B
Model ID: 03031000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 6.02
Application Version: 5.01
Model Definition Version: 0
Library Type: 3
Class Name: Motor Control Class B
Class Hierarchy: 04 : 11 : 06
Command Class Base: 26
Command Versions: 20v1 85v1 86v1 8Ev1 55v1 56v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 60v4 22v1 25v1 26v4 6Cv1 32v3 70v1 71v1 72v1 73v1 75v1 7Av1
Encryption Status: Enabled for Commands 60 85 86 26 72 8E 70 71 32 73 75 59 5A 5B 7A
Multi-Endpoint Types: 1:(11 : 06), 2:(11 : 06)
Multi-Endpoint Classes: 1:[5E 98 9F 6C 22], 2:[5E 98 9F 6C 22]
Features: routing, beaming, security, energyMeter
Neighbors: 5, 6, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 27, 28, 29, 33, 35, 51, 54, 60, 61, 84, 86, 87, 90, 95, 100, 101, 102, 104, 107, 115, 122
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
If you want anything else just ask! I know I'm not around the forums that much these days so if I don't reply to something just bump me with an email!
Fri Jun 19, 2020 4:45 pm
Re: Fibaro FGR-223
Thanks – we'll look into it!
Fri Jun 19, 2020 5:13 pm
durosity offline
Re: Fibaro FGR-223
Most excellent. I’m hoping to get this window opener hooked up soon, so of course make it utter top priority.. no sleeping, no eating.. don’t even waste time breathing!
Ok fine breathing is permitted.. ugh.. you’re so needy.
Sat Jun 20, 2020 12:34 am
siclark offline
Re: Fibaro FGR-223
You disappear for ages then come back and immediately it’s all me me me and want want want.....
So, glad nothing has changed.
Sat Jun 20, 2020 1:11 am
Re: Fibaro FGR-223
You really think Jay’s gonna unlock the window down there so you can “test a new module”.
He ain’t gonna let you escape that easily!
Sat Jun 20, 2020 1:12 am
durosity offline
Re: Fibaro FGR-223
Darn tootin’!
Now where’s indigo 8?
Sat Jun 20, 2020 1:14 am
durosity offline
Re: Fibaro FGR-223
Damn, foiled! He’s held me captive for what feels like an eternity now forcing me to test day in, day out.. I think he may be GlaDOS!
Sat Jun 20, 2020 1:40 am
siclark offline
Re: Fibaro FGR-223
Darn tootin’!
Jay and Matt have been slacking without you complaining, I mean cracking the whip.
Sat Jun 20, 2020 1:47 am
durosity offline
Re: Fibaro FGR-223
Well their lackadaisical says are over.. Before you know it Indigo X will be out!
Thu Jul 16, 2020 7:49 am
ChiefMonk offline
Re: Fibaro FGR-223
I have a load of these to go into new house. Here is the bit from my log just in case it helps.
Z-Wave Indigo Device "030 - Mulitlevel Switch" Z-Wave Properties:
Node ID: 30
Model ID: 03031000
Library Type: 3
Neighbors: - none -
Regards
Chris
Wed Jul 29, 2020 1:33 pm
ChiefMonk offline
Re: Fibaro FGR-223
Hi Matt,
As mentioned we are building a house and need to get these modules installed for our blinds. To coordinate with the electricians and make sure I am ready to configure and test the modules as they install them (likely to be in about 4/6 weeks time) I would need to know if / when FGR-223 will likely be added to supported modules.
It would be great if you could give me an idea of how long it would likely be -- or --
if you dont see that happening then I will see if I can get them swapped for the older module, which might be tricky but could be worth a try.
If there is anything that I can do to help please let me know.
Chris
Wed Jul 29, 2020 4:20 pm
agame offline
Re: Fibaro FGR-223
Given such enthusiasm for proper motor control support I hope someone can also look at support for the Fakro openers :wink: ....been discussed on other threads since 2015. There's a raw z-wave workaround for a stop message but open/close status doesn't get reported properly which is frustrating.
