iBeacon shows as expired but it's not
Sun May 31, 2020 4:44 pm
Re: iBeacon shows as expired but it's not
does your RPI have a single ip#?
!!! If not, no guarantee what so ever!!!
That will screw things up big time, constant switching, expiring ...
Sun May 31, 2020 5:00 pm
johnfdl offline
Yes, it has a single IP. I included the ifconfig in a previous post showing it had just one IP after I disabled the wireless.
Sun May 31, 2020 5:02 pm
Ok could you do debuglog all in config
And post plugin.log
Mask the passwords
Sun May 31, 2020 5:08 pm
johnfdl offline
rPi and Beacon is currently showing up. Here's the log;
logsnip.txt
(101.88 KiB) Downloaded 144 times
Sun May 31, 2020 5:16 pm
There is still a connect problem
What is your connection speed. Do a ping
Sun May 31, 2020 5:24 pm
johnfdl offline
Johns-MacBook-Pro-3:~ johndeluca$ ping 192.168.0.43
PING 192.168.0.43 (192.168.0.43): 56 data bytes
64 bytes from 192.168.0.43: icmp_seq=0 ttl=64 time=2.603 ms
64 bytes from 192.168.0.43: icmp_seq=1 ttl=64 time=6.065 ms
64 bytes from 192.168.0.43: icmp_seq=2 ttl=64 time=1.432 ms
64 bytes from 192.168.0.43: icmp_seq=3 ttl=64 time=3.656 ms
64 bytes from 192.168.0.43: icmp_seq=4 ttl=64 time=2.349 ms
64 bytes from 192.168.0.43: icmp_seq=5 ttl=64 time=1.453 ms
64 bytes from 192.168.0.43: icmp_seq=6 ttl=64 time=1.353 ms
64 bytes from 192.168.0.43: icmp_seq=7 ttl=64 time=12.735 ms
64 bytes from 192.168.0.43: icmp_seq=8 ttl=64 time=2.144 ms
64 bytes from 192.168.0.43: icmp_seq=9 ttl=64 time=2.220 ms
64 bytes from 192.168.0.43: icmp_seq=10 ttl=64 time=12.672 ms
64 bytes from 192.168.0.43: icmp_seq=11 ttl=64 time=2.344 ms
64 bytes from 192.168.0.43: icmp_seq=12 ttl=64 time=2.206 ms
64 bytes from 192.168.0.43: icmp_seq=13 ttl=64 time=3.668 ms
64 bytes from 192.168.0.43: icmp_seq=14 ttl=64 time=2.174 ms
64 bytes from 192.168.0.43: icmp_seq=15 ttl=64 time=1.993 ms
64 bytes from 192.168.0.43: icmp_seq=16 ttl=64 time=2.494 ms
64 bytes from 192.168.0.43: icmp_seq=17 ttl=64 time=2.235 ms
64 bytes from 192.168.0.43: icmp_seq=18 ttl=64 time=6.399 ms
64 bytes from 192.168.0.43: icmp_seq=19 ttl=64 time=12.955 ms
64 bytes from 192.168.0.43: icmp_seq=20 ttl=64 time=2.255 ms
64 bytes from 192.168.0.43: icmp_seq=21 ttl=64 time=1.658 ms
64 bytes from 192.168.0.43: icmp_seq=22 ttl=64 time=1.174 ms
64 bytes from 192.168.0.43: icmp_seq=23 ttl=64 time=3.698 ms
64 bytes from 192.168.0.43: icmp_seq=24 ttl=64 time=2.184 ms
^C
--- 192.168.0.43 ping statistics ---
25 packets transmitted, 25 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 1.174/3.845/12.955/3.529 ms
Note: MacBookPro is connected via Wifi | rPi is ethernet connected.
Sun May 31, 2020 6:01 pm
so it is not speed.
there must be some other messages in your logfile
could you restart the plugin?
and which version are you running?
Mon Jun 01, 2020 12:56 pm
johnfdl offline
Karl,
I ordered two Nonda iHere beacons from amazon. They are coming tomorrow. Let me experiment with them to be sure I don't just have a beacon that has gone bad. If I have the same trouble, I'll re-engage you....but I don't want to drag you down a rathole if it's just a bad beacon.
The rPi has been up since yesterday.
Mon Jun 01, 2020 11:06 pm
Just FYI: Beacons stop pinging when the iPhone app is running
Wed Jun 03, 2020 9:58 pm
johnfdl offline
Yes....I am aware of that. I killed the app on my phone. New Beqcons arrived today and appear to be working properly....so perhaps the Beacon is the issue.
Thu Jun 04, 2020 8:43 am
just FOI- the beacon that does not work: what kind of beacon is it?
Sun Jun 07, 2020 2:12 pm
johnfdl offline
Nonda iHere (triangle usb). It worked fine for years, but seems to have gone bad. My two new Nonda iHere beacons have been flawless now for a week.
Sun Jun 07, 2020 2:49 pm
when you charge it does it go green?
Sun Jun 07, 2020 8:39 pm
johnfdl offline
Yes, it does go green, so it's not that it is dead.
Sun Jun 07, 2020 10:56 pm
You could try the iHere app to revitalize it
Don’t forget to stop the app once you are done.
Users browsing this forum: No registered users and 22 guests
