Hi Matt,
ok, thanks.
I've tried twice (last time today in the morning) but I didn't succeeded, it still shows 5% battery.
Here are the logs from the exclusion/inclusion.
- Code: Select all
29. May 2020 at 10:56:22
Z-Wave started controller exclusion mode
Z-Wave controller excluded module: 023 - Rauchmelder Wohnzimmer
Z-Wave Error device "Rauchmelder Wohnzimmer" no longer has a matching module 023 in the controller
Z-Wave Error device "Vandalismussensor Rauchmelder Wohnzimmer" no longer has a matching module 023 in the controller
Z-Wave Error device "Temperatursensor Wohnzimmer" no longer has a matching module 023 in the controller
Z-Wave Error to re-enable the device with a new z-wave module, press the "Define and Sync..." button in the device dialog
Z-Wave stopped controller exclusion mode
29. May 2020 at 10:57:26
Z-Wave started controller inclusion mode with encryption
Z-Wave controller included module: 024 - Notification Sensor
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
29. May 2020 at 10:58:13
Z-Wave Syncing - started for "024 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 4, 10
Z-Wave Syncing - assigning return route to "024 - Notification Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smoke Sensor (FGSD002) - 0C021002
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.03
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 22v1 71v1 70v1 31v8 72v1 73v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: 20 84 85 8E 70 71 5A 9C
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 360 minutes
Z-Wave Syncing - device "024 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - added group 2 association to interface
Z-Wave Syncing - added group 5 association to interface
Z-Wave Syncing - retrieved parameter 2 "Notification flags" is 0
Z-Wave Syncing - device "024 - Notification Sensor" parameter 2 "Notification flags" changed to 3
Z-Wave Syncing - retrieved parameter 10 "Group 2 command type" is 0
Z-Wave Syncing - retrieved parameter 11 "Group 2 command value" is 255
Z-Wave Syncing - retrieved parameter 1 "Smoke sensitivity" is 2 "Medium"
Z-Wave Syncing - retrieved parameter 3 "Visual alerts" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 4 "Audible alerts" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 20 "Temperature interval" is 1 * 10 seconds
Z-Wave Syncing - retrieved parameter 21 "Temperature sensitivity" is 10 * 0.1°C
Z-Wave Syncing - retrieved parameter 30 "Temperature threshold" is 55 °C
Z-Wave Syncing - retrieved parameter 31 "Temperature alarm" is 1 "10 Seconds"
Z-Wave Syncing - retrieved battery level of 5%
Z-Wave Syncing - changed device "Rauchmelder Wohnzimmer" address from undefined to 024
Z-Wave Syncing - changed device "Vandalismussensor Rauchmelder Wohnzimmer" address from undefined to 024
Z-Wave Syncing - changed device "Temperatursensor Wohnzimmer" address from undefined to 024
Z-Wave Syncing - complete
I'm thinking to do it this way:
1. Exclude
2, Delete teh device from Indigo
3. Reset it (there is a procedure described in the manual).
4. Includ & create the device again
What do you think?
Yassi
